Old 03-23-2013, 05:31 PM   #1
shinotheweevil
shinotheweevil is on a distinguished road
shinotheweevil's Avatar
2001 SL2
Default SL2 Check engine light flashing
Hey guys, so I bought a SL2 at an auction and was running great till I started losing power and then the check engine light began to flash. The light then turned off after a few seconds and my power came back to me. Does anyone know whats wrong? My car is a 2001 SL2 with automatic transmission if that helps.
Add to shinotheweevil's Reputation
Rate the quality of this post and help shinotheweevil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shinotheweevil is offline   Reply With Quote
Old 03-23-2013, 06:09 PM   #2
brags
brags will become famous soon enoughbrags will become famous soon enough
1996 SL1
Default Re: SL2 Check engine light flashing
You have a missfire get it scand and post code up ASP...
before it harms Your Catalytic Converter..
" Any man that doesen"t share his knowledge in cars is wrong to do !"
Add to brags's Reputation
Rate the quality of this post and help brags reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brags is offline   Reply With Quote
Old 03-23-2013, 08:07 PM   #3
off-track
off-track's Avatar
+1 on getting the code read. I know that can be difficult in CA. Meanwhile, pull the plugs and see how they look.
A flashing MIL equals SEVERE misfire. If it starts flashing again BACK OFF the throttle so it stops. If not the results can be MUCH worse than just a damaged Cat (btdt).
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 03-25-2013, 01:31 PM   #4
shinotheweevil
2001 SL2
The Only Code I got is p0172 which is running rich.
Any ideas in getting that fixed?
Old 03-25-2013, 09:46 PM   #5
off-track
off-track's Avatar
Nothing I've got indicates that should cause the flashing MIL. Did you check history/pending codes as well?
As far as the P0172 goes, the laundry list of things to check:
Fuel pressure high
Fuel injectors leaking
O2S-1 contaminated
Vacuum leak around MAP sensor
EGR valve stuck open
EVAP purge solenoid stuck open
Restricted exhaust or restricted air induction
Added OEM CC
Old 03-26-2013, 05:50 PM   #6
shinotheweevil
2001 SL2
So I checked the history/pending codes and there aren't any. Only running rich :/
Also, Where would I find a MAP sensor on a 2001 Saturn SL2? I have the book thats only from 1991-1999 and it looks different from my old saturn.
If it helps any, when I smogged the car, emissions passed BUT the light.
Flashing Check Engine Light - 2004 Vue addicted2mickey Vue Tech 19 01-07-2014 10:21 PM
2003 4cyl Rough Idle, power loss, check engine light flashing mariopalumbo Vue General 4 08-29-2010 10:19 PM
Flashing check engine light! RedLineWant2be Ion Tech 5 12-31-2009 06:16 PM
Flashing engine light / shaking - 99 SL2 VandyZ S-Series Tech 18 01-18-2009 01:53 AM
Flashing Service Engine Light - 2002 Vue gajames33 Vue Tech 7 01-30-2007 10:09 PM
