Old 03-23-2013, 04:03 PM   #1
kippster41493
kippster41493 is on a distinguished road
Mad starts, runs dies
I just replaced my head gasket on 96 SL2, I went to start it, it misfired once, ran for a few seconds, and died. Is my timing off? That's pretty much all I can think that will cause this problem.
Add to kippster41493's Reputation
Rate the quality of this post and help kippster41493 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kippster41493 is offline   Reply With Quote
Old 03-24-2013, 07:11 AM   #2
Default Re: starts, runs dies
Search the sticky about the original coolant sensor and brass replacement.
There are many threads about timing with pictures. Search.
What's the history of this engine? Parts replaced, mileage, reason for replacing the head gasket.
The engine ran so either timing is fine and something else is causing the random die off or mistiming wrecked a valve/piston........................... You can manually turn the engine over after removing spark plugs and feel for damage.
Starts, Runs, then Dies. SgtDetritus S-Series General 7 09-24-2012 02:56 PM
96 Saturn SL runs dies then starts roscoemegan96sl S-Series Tech 21 08-16-2008 12:01 AM
SC2 Starts, runs for a few minutes, then dies Dukie S-Series Tech 27 06-22-2008 02:52 PM
SC1, Starts, runs, dies Scrapsflippy S-Series Tech 2 01-12-2008 05:48 PM
Starts in cold then dies, then starts again ??? Scyan S-Series Tech 10 02-16-2003 09:16 PM
