Old 03-20-2013, 12:43 AM   #1
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
Default Can I get some opinions?
I was thinking about replacing the factory fogs with some driving lights to aid the low beams. My idea was that the factory fog location is low enough that driving lights shouldn't blind oncoming traffic. (I'll aim them down if need be) Thoughts on this? Also, if I did this, would there be a way to use the stock switch to turn them on/off? IIRC the stock switch only supplies ground to the factory fogs, so would I be able to use this to ground a relay to power the driving lights?
Current:
1999 SC2, 186,XXX
Past:
1989 Mustang LX, Unknown mileage(JY engine in it when I got it)
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 03-20-2013, 08:29 AM   #2
Default Re: Can I get some opinions?
Unless the coupes are different, the stock switch triggers the relay under the hood. You should be able to wire in aftermarket lights directly in place of the OEMs. Fitment is another question; there are several aftermarket round lights that perfectly match the OEMs on the sedans/wagons, but the coupes are an odd duck.
There's also a simple mod to keep them on with the high beams. I posted a thread about it, but for some reason not finding it.
Add to madpogue's Reputation
Old 03-20-2013, 08:35 AM   #3
ninetynineSC2
I had read that the stock wiring wouldn't be able to handle the increased draw from aftermarket lights. It'd be fairly simple to upgrade it though.
Current:
1999 SC2, 186,XXX
Past:
Old 03-20-2013, 10:30 AM   #4
I've been running 55-watt H3s in my '96 SW2 for prob. close to 10 years now. All OEM wiring, except the last bit spliced into the H3 connector. No problems.
The thing you don't want to do is put higher power bulbs in the stock _housings_. The brighter bulbs burn hotter, and will melt the plastic housings.
Old 03-20-2013, 12:48 PM   #5
ninetynineSC2
Cool. Think driving lights in place of fogs would blind oncoming traffic (even though they're low and would be aimed)?
Current:
1999 SC2, 186,XXX
Past:
Old 03-20-2013, 01:22 PM   #6
They'll probably be no worse than the fogs... but that depends on how bright they are
I'm thinking about going to LED driving lights, aimed low... mostly so other drivers can see me (may disable the DRLs)
Old 03-20-2013, 03:38 PM   #7
I've never been "flashed" having my driving lights on. I've walked out 10, 50, 100 yards in front of the car and looked at them from the equivalent of a passenger car driver's seat position. Not blinding at all. And even though they're driving lights, they throw a fair amount of light to the sides of the road, which is priceless for spotting crossing critters on small rural roads.
Old 03-20-2013, 07:46 PM   #8
dummo
dummo is just really nicedummo is just really nicedummo is just really nicedummo is just really nicedummo is just really nice
dummo's Avatar
1997 SW2
Have you considered a pair of small machine guns instead?
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 03-20-2013, 09:05 PM   #9
ninetynineSC2
What lights do you have? Also, I've DEFINITELY considered mounted guns
Current:
1999 SC2, 186,XXX
Past:
Old 03-22-2013, 12:05 AM   #10
ninetynineSC2
So I might get some driving lights this weekend...Are the $20-30 ones any good? I don't need anything REALLY bright, just enough to light up a little further for the low beams.
Current:
1999 SC2, 186,XXX
Past:
Old 03-22-2013, 01:08 AM   #11
Not really. For decent results you have to spring for the largest reflector area you can tolerate and the high quality bulbs. Once you find the physical size criteria then you can find out who makes the good lights and go shopping for a used set. Plan on buying good bulbs as well.
Old 03-22-2013, 12:06 PM   #12
ninetynineSC2
By largest reflector area, would that mean the biggest size light I can find?
Current:
1999 SC2, 186,XXX
Past:
Old 03-22-2013, 02:20 PM   #13
Round lights make a round beam that is modified by the lens. Oval or rectangular lamps produce a similarly shaped beam. Rectangular or oval lamps are about all that will fit and not look strange. This will provide some ideas. http://www.rallylights.com/hella/Aux...LampsGrid.aspx
http://www.danielsternlighting.com/p.../products.html
Need some opinions on a 94' SC2 Col.FUBAR S-Series Tech 7 06-18-2009 11:17 AM
Opinions on PAL please Michel1961 Aura General 18 08-10-2008 06:19 PM
Another SL?? Opinions first zukgod1 S-Series General 16 01-17-2008 06:12 PM
need opinions bo. S-Series General 14 01-09-2008 08:36 PM
Want opinions sc288203 S-Series General 11 10-27-2003 12:22 AM
