Old 03-17-2013, 02:35 PM   #1
wubba68
wubba68 is on a distinguished road
Default no washer fluid from front wipers
I am new to the forum but Need help !!! we are going on vacation at the end of the month and have no fluid coming out of the front wipers. I have replaced the pump and checked the relay by swapping it out for the rear it works fine. I do get a clicking noise from the relay butt nothing from the pump. oh it's for an 07 outlook XR
Thanks,
Todd
Add to wubba68's Reputation
Rate the quality of this post and help wubba68 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wubba68 is offline   Reply With Quote
Old 03-17-2013, 02:51 PM   #2
Default Re: no washer fluid from front wipers
Welcome to the Board.
Check for power and ground at the connector for the pump. Down and dirty way is to use a test light across the two wires of the pump connector. Activate the washer switch and see if the test light comes on. If it does then you are good up to the connector. If it doesn't then you need to individually check power and ground.
Add to ssicarman's Reputation
Old 03-18-2013, 03:52 PM   #3
wubba68
I have no power at the pump any suggestions on what I should try now? Could it be the switch on the signal lever?
Old 03-18-2013, 07:05 PM   #4
Have you checked the fuse for the wipers?
If the fuse is good then check the wiring from the pump back.
Old 03-18-2013, 09:27 PM   #5
wubba68
That was the first thing I checked but I will a check again and trace the wires, is there any way to jump off the rear one ?
2001 LW300 Wipers work, but no washer fluid? OhioLW300 L-Series Tech 2 08-12-2011 05:41 PM
What's this part in front of the washer fluid tank? BennySL2 S-Series Tech 3 08-21-2010 11:20 PM
washer fluid doubleb99 Astra General 1 06-14-2010 09:28 PM
Windshield Wipers and Washer theboss429 S-Series Tech 4 02-15-2010 08:37 AM
No low speed wipers / washer ? jerry483 S-Series Tech 2 12-21-2003 08:51 PM
