Old 03-15-2013, 12:13 AM   #1
Ikiris
Ikiris is on a distinguished road
Ikiris's Avatar
Default Shifting to second at 3000 almost every time
2004 Saturn Vue 3.5L V6 AWD. It seems as that even when i am very light on the gas, it almost always shift at or around 3000rpm. Is this normal for the crazy Honda drivetrain(Have never owned an Import)
All gears shift nicely though.
04 Vue 3.5L V6 AWD 297000 km
00 Impala LS 3.8 V6 Loaded 262000 km SOLD
98 SC2 5speed-265000 km SOLD
Add to Ikiris's Reputation
Rate the quality of this post and help Ikiris reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ikiris is offline   Reply With Quote
Old 03-15-2013, 09:35 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Shifting to second at 3000 almost every time
Try watching the speedometer rather than tach. I've attached an extract for you to see typical correlation of throttle setting with gear changing speeds.
The chart only shows three different throttle settings - 7.5, 44 and 100% but you'll eventually be able to fill in the blanks.
Keep in mind there's lots more than gear changes going on in the transmission. Unlike older transmissions, the 5AT (GM RPO code for Hondamatic) will engage the torque converter clutch (TCC) in all gears except 1st gear.
This is done to eliminate the inefficiencies normally encountered by using strictly fluid coupling between engine and transmission for urban driving.
The down-side of extended TCC operation is "tach-watchers" will notice subtle RPM changes - even when traveling at fixed speed on what appears to be level terrain.
Old 03-15-2013, 09:58 AM   #3
Ikiris
Ikiris's Avatar
Ok cool, definitely not what I expected. Glad this is fairly normal. I have a bunch of work to do to the vehicle over the next few weeks. I just bought it last Saturday. Going to change out all of the fluids, and do the timing belt in a month or so.
Old 03-15-2013, 12:54 PM   #4
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
I'll chime in...
My '04 does the same thing. My former '05, after having the torque converter campaign done, turned into a different animal. It would shift into 2nd well before 3,000 RPM. If I remember correctly, it was more like 2,400 RPM and slightly lower under light throttle.
Sadly, GM ignores the '04 under that campaign. I just think of it as being more aggressive, almost sporty and speedy.
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 03-15-2013, 02:49 PM   #5
Ikiris
Ikiris's Avatar
Originally Posted by RedGeminiPA View Post
I'll chime in...
Thanks so much. Just glad it's not an issue, just normal. haha I do like the vehicle I have owned it for a week now. Drives great. Putting in my Pioneer AppRadio this weekend.
It's that time again - 1999 Saturn SL2 automatic shifting gone crazy. ncinerate S-Series Tech 15 12-10-2011 11:31 PM
Hard Time Shifting Piczaso S-Series Tech 3 02-18-2011 04:47 PM
Idles @ 3000! Help!!! miker351w S-Series Tech 4 08-02-2008 10:33 AM
Oil Change at 3000? TheMarshall 2008 Vue 8 03-03-2008 07:52 PM
Mr. 3000! ThePlainsman Outlook General 16 04-11-2007 10:35 PM
