Old 03-11-2013, 06:26 PM   #1
shoothebunnies
shoothebunnies is on a distinguished road
2000 SL2
Default Charging system issue
Was driving last night and the battery indicator light came on. I shut off all accessories to the minimum as I had 23 miles to the next town.
The light would go off every time I would come to a stop, then illuminate again as I accelerated. The car had no power. Made it to the parts store and they tested it saying the diode in the alternator and battery were both bad. The guy was really confused.
Short version I bought a battery just in case and headed toward home. After about 15 miles with lights dimming, the light went off, lights went back up to full power and away I went.
Slightly confused as I drove the car 197 miles home with no issues and it started right up this morning.
Where do I start?
Thanks in advance.
Willis
1994 SL2 368k
2000 SL1 224K - RIP
1998 SL2 189K - RIP
1996 SL2 237K - Sold
Add to shoothebunnies's Reputation
Rate the quality of this post and help shoothebunnies reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shoothebunnies is offline   Reply With Quote
Old 03-11-2013, 06:34 PM   #2
Chazberry
Chazberry's Avatar
Default Re: Charging system issue
Could be the Alternator going intermittent before total failure. You want to measure how many volts it is putting out.
Add to Chazberry's Reputation
Old 03-12-2013, 12:03 AM   #3
el diablo viejo
el diablo viejo's Avatar
1994 SW1
Sounds like it may be warning of an impending alternator failure, however things to check in the meantime: 1) Serpentine belt tightness and condition ( cracked/missing ribs ) 2) Belt tensioner springback and pulley, idler pulley 3) Battery voltage with engine off ( about 12.5 volts ) and then with engine running ( 13.5 - 14.5 volts ) 4) voltage at battery when idiot light comes on -if possible.
97 sl2 a/t 104 K
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98 Charging System Problems DarrylLeeOHS30 S-Series Tech 14 03-10-2011 11:50 AM
'95 SC2 Charging System 72greg S-Series Tech 3 02-01-2011 11:00 AM
Charging System Issue Got Me Stumped KevinVarnes S-Series Tech 21 11-15-2008 11:53 PM
Charging System Question Photomatt S-Series Tech 9 03-23-2006 08:00 AM
Charging System Issue SL1Joe S-Series General 4 10-03-2004 04:41 AM
