Old 03-05-2013, 09:40 AM   #1
ddemier7
ddemier7 is on a distinguished road
ddemier7's Avatar
2004 ION-1 Sedan
Question 2004 Saturn Ion Transmission Fluid Change? HOW
I recently got a 2004 Saturn ion (series 1) 4 door with a automatic transmission and a 2.2 motor. I would like to change the transmission fluid because this car has 189,000 miles on it, however runs and shifts excellent. I googled the access fill/drain holes and looked on my transmission and I had neither drain/fill holes?
I called Oriellys and Autozone and they are telling me it is a non servicable transmission on the series 1?? Is this info correct or is there another way to flush my fluid? I changed my spark plugs to NGK and changed my oil and put a new fuel filter on it.
Add to ddemier7's Reputation
Rate the quality of this post and help ddemier7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddemier7 is offline   Reply With Quote
Old 03-05-2013, 10:23 AM   #2
buckeyegirl
buckeyegirl is on a distinguished road
2004 ION-1 Sedan
Default Re: 2004 Saturn Ion Transmission Fluid Change? HOW
The parts counter folks are mis informed. There is a drain bolt underneath the car. Drain and refill with Toyota IV transmission (yes it is the correct fluid for the 4 door 2004 Ion Aisin made transmission) and refill with same amount. The dipstick tube does have a small bolt holding the tube/cap on. Remove it, place a funnel in and pour. Simple. Might have to do 2 or 3 drain and fills over the next 100 miles to achieve a thorough exchange of fluid.
Add to buckeyegirl's Reputation
Rate the quality of this post and help buckeyegirl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
buckeyegirl is offline   Reply With Quote
Old 03-05-2013, 02:42 PM   #3
kg6mvb
kg6mvb will become famous soon enoughkg6mvb will become famous soon enough
kg6mvb's Avatar
2003 ION-1 Sedan
The drain plug is a 24mm hex. It is the lowest "bolt" on the engine side of the transmission.
Fill via the dipstick. It's yellow and held in place by a 12mm bolt. You will need a funnel, and fill slowly. The fluid is expensive and hurts when it spills on the garage floor.
Toyota T-IV is the fluid you need, and the Toyota dealer is cheaper than chevy. A drain and fill on mine takes a bit over four quarts. I would buy five.
Proud to be a member of both the Ham Radio and Saturn Cults.
Avitar is a Saturn V rocket engine.
Add to kg6mvb's Reputation
Rate the quality of this post and help kg6mvb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kg6mvb is offline   Reply With Quote
Old 03-05-2013, 04:15 PM   #4
2006 ion2
2006 ion2 has a spectacular aura about2006 ion2 has a spectacular aura about
2007 ION-2 Sedan
They never said they have a sedan, but I think only sedans came in level 1 (not series). Don't karten to buckeyegirl, the drain hole is on the side of the trans case behind the frame rail. Above it is a "fill to" hole, once fluid drains out of this hole, it's full.
If you have a coupe, it's a different story.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 03-05-2013, 09:29 PM   #5
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Ok thanks guys. I see the fill hole with the yellow tab on top of the transmission. I unbolted it and that yellow tab would not buge! Wheww... Is it just really stuck on or do i need to pry it off with a little putty knife? I will crawl under there this weekend and look for a drain bolt! Yayyy!! I bet this fluid is nasty! Im gona flush the brake fluid cuz i got black sludge in the bottom of the resivor! poor car but boy it runs good! Any tips on maintenence on this ion? Thankx guys
Old 03-05-2013, 10:12 PM   #6
2006 ion2
2007 ION-2 Sedan
My entire thread on pm that's stickied at the yup of the tech section
2007 Saturn Ion 2
Old 03-06-2013, 12:03 AM   #7
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Ok i checked out your thread theres some good stuff in there. Kinda got me curious if my ngk plugs are going to work good. Glad i didnt use bosh plugs!!
Old 03-06-2013, 10:12 PM   #8
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Anyother ideas outhere
Old 03-07-2013, 07:53 PM   #9
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Can somebody upload a clear picture of their transmission drain hole on a saturn 2004 (1)with automatic? I canot locate this hex head drain hole. I dont have the fill/ drain hole on the drivers side of the transmisson behind the strut.
Old 03-07-2013, 10:32 PM   #10
2006 ion2
2007 ION-2 Sedan
It's the only hex head plug with the framerail in the way on the side of the transmission.
2007 Saturn Ion 2
Old 03-08-2013, 01:55 PM   #11
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
I will probably have to jack car up pretty high cuz i sware im not seeing it and im looking around the frame rail. I have Castrol Transmax Dex/Merc for use in ford gm vehicals.will this work or return it and get the Toyota transmission fluid stuff. I had already bought this Castrol but i still have my reciept from AutoZone.let me know guys cuz i know nothing about Saturns.
Old 03-08-2013, 02:06 PM   #12
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
"2006Ion2" dont forget I have a 2004Ion 1, my drain port is not in the left front drverside fender well behind shock close to the frame rail. I have neither fill or drain on the drivers side of the transmissionin side fender tire well.im under the car looking and nothing appears to be a drain hole for fluid. Just tranny bolts . Any other suggestions. Thanks guysi work at a body shop i can put this ion on our lift but i aint seeing a drain plug yet.
Old 03-08-2013, 04:29 PM   #13
kg6mvb
kg6mvb's Avatar
2003 ION-1 Sedan
On my 2003, it's the only 24mm hex "bolt". It's on the engine side of the transmission and is the lowest bolt. It's on the side, not the bottom. I fill via the dipstick and a long funnel.
I don't know about a fill to plug, I just kept checking with the dipstick. Mine takes just a bit over four quarts on a drain and refill. I wouldn't want to remove the wrong bolt (thinking its a fill to hole) and have something fall apart inside.
2004 should have the same transmission, provided it's the sedan. The quad coupes in 2003-2004 all had the VTI. That's a whole different animal that you don't want.
Saturn changed the transmissions on both in 2005 model year.
Old 03-08-2013, 05:23 PM   #14
2006 ion2
2007 ION-2 Sedan
Saturn put the drain and fill to holes in the same general area for all but the vti. Only use toyota or saturn t-iv fluid.
2007 Saturn Ion 2
Old 03-08-2013, 09:12 PM   #15
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Ok i will get the toyota fluid but as far as drain hole goes i will put it on a lift and inspect.its on the engine side of the transmission.hmmm anyone out there got a pic. I see torx bolts but they hold the casing on. Theres not 1 seprate tirx bolt that resembles a drain plug. Hmm
Old 03-09-2013, 08:46 PM   #16
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
i found the drain hole. it was alot bigger than what i expected.
Old 03-11-2013, 11:22 PM   #17
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
i had to get screw driver and pry up on dipstick after i unbolted it. that oring had a tight....i mean tight seal,wow. checked fluid and wow it was almost brown! i bet the prior owners never changed it. yukkkk. will it shift smoother if i change it?
Old 03-11-2013, 11:56 PM   #18
2006 ion2
2007 ION-2 Sedan
It should, I would do a change (not flush), drive it for a week, change it again.
2007 Saturn Ion 2
Old 03-12-2013, 12:41 AM   #19
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
yeah i mean a change not a flush . so change fluid with toyota stuff and drive maybe a full tank of gas about 300 miles and change fluid again? and why did saturn put a bolt on the dip stick? i would never of guessed that was a dip stick and ive been in the collision business for 12 years.
Old 03-12-2013, 06:08 AM   #20
2006 ion2
2007 ION-2 Sedan
Yes. I think that was aisin's call, but think about it, the more sealed the transmission, the longer the fluid can last.
2007 Saturn Ion 2
2007 Saturn Vue Automatic Transmission Fluid Change greensaturn How-To Library 9 12-31-2012 01:04 AM
2003 Saturn vue V6 transmission fluid change jcc007 Vue Tech 30 12-30-2011 12:13 PM
What mileage should I change the automatic trans fluid 2004 ion2 SC Saturn Owner Ion General 9 01-14-2010 02:09 PM
5spd Transmission Fluid Change - Fluid? Satsational S-Series Tech 17 10-20-2008 05:57 AM
122,000 miles on transmission with no transmission fluid change in car's history. foo General Saturn Discussion 10 04-22-2008 05:04 PM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
