Old 02-26-2013, 05:29 PM   #1
sdowney717
sdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of light
Default Clean O2 sensors with muriatic acid?
Curious if dipping them in acid would clear off any interfering coating.
I ran some old boat gas in the Roadmaster 94 wagon. Engine sputtered to a stop. Fuel filter was blocked. New filter and disconnected the lines at the intake manifold and flushed the lines using the fuel pump. Engine is again running smooth, however the check engine light came on and stays on. So will check the code. Wonder if it could be the O2 sensor?
This gas was about 8 yrs old and I guess gummy. Put in 2 gallons out of 10. At least the filter caught it and did not clog the injectors. The gas likely had dissolved metals and other invisible crud. Otherwise it looked ok. anyway that is the last of 80 gallons. I eventually managed to use it up in the boat. Boat has carbs and I loop filtered over and over and diluted 50-50 with new gas. Took about a year of boating to finally use it all.
Add to sdowney717's Reputation
Rate the quality of this post and help sdowney717 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdowney717 is offline   Reply With Quote
Old 02-26-2013, 06:19 PM   #2
Default Re: Clean O2 sensors with muriatic acid?
The only way to clean an O2 sensor is to remove it and roast it in a torch flame while monitoring the output and alternative heating and cooling the tip and when it changes state in less than 60 seconds it is clean again.
Old 02-26-2013, 06:59 PM   #3
sdowney717
Thanks for the torch idea.
How does lead or metals contaminate the sensor? So then I was thinking disolve it off with acid.
The boat tanks are monel metal and likely copper and nickle are in the gas.
The gas should not have any lead since that was phased out long ago.
What else coats or ruins these sensors?
If it turns out 02 sensor code thrown, I will likely try various things.
Old 02-26-2013, 08:07 PM   #4
Just replace the sensor, Denso or NGK/NTK will work and RockAuto sells them.
Old 02-27-2013, 10:45 AM   #5
sdowney717
Do you know where the coolant temp sensor is on the GM LT1 engine?
I got a code 15.
You can read the codes directly in the climate control panel
http://www.buickforums.com/forums/sh...ad.php?t=10691
Old 02-27-2013, 11:02 AM   #6
No, but google does.
Old 02-27-2013, 02:02 PM   #7
sdowney717
The temp sensor is bad, reads 128,000 ohms, so it tells the ECU the temp is less than -40 degrees.!
It is located under the air intake hoses to driver side of water pump.
Function is a standard thermistor which changes ohms with temperature change.
http://www.gmtuners.com/tech/CTS_ICM.htm
Going to get one from AZ.
One odd symptom is car wont start unless floored, which others noted on some forum. And the car has a temp gauge which works like it always did. Different sensor?
Maybe the bad gas and sensor hit all same time. The old fuel filter when blow thru using mouth has a lot of resistance compared to the new filer.
Old 02-27-2013, 02:19 PM   #8
The water/alcohol mix blocks fuel filters solid.
Old 02-27-2013, 04:19 PM   #9
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
Are we talking about a Buick here?
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 02-27-2013, 06:29 PM   #10
sdowney717
Yes, and the new coolant sensor fixed the problem. Runs good again.
I check fuel pressure and it is 46psi, normal range is 41 to 47.
here is a very good info diagnostic page, I will post in case someone googles into this thread.
http://www.justanswer.com/buick/712v...-corvette.html
Old 02-28-2013, 12:21 AM   #11
colonelhogan44
Well, glad you got it resolved.
Saturnfans is a strange place to post Buick questions, but whatever.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Use Saturn oem O2 sensors or generic sensors? 2strkBlu S-Series Tech 25 08-09-2016 01:55 PM
Clean camshaft sensors - 2.4 L golftango Aura General 8 09-02-2014 04:17 PM
Aura Green Line Lead Acid Battery model/group size? drjby4 Aura General 4 02-05-2013 01:50 PM
My SC2 is an acid junkie. hit_n_run S-Series General 20 03-03-2008 10:24 PM
o2 sensors jonsq54 Vue Mods 0 03-18-2007 08:57 PM
