Old 02-20-2013, 02:42 PM   #1
srez
srez is on a distinguished road
Dazed What type of motor for 2005 Vue
It seems that I have a rod knock. Somehow the vehicle was short 4 quarts of oil. I'm told that the motor needs to be replaced. I've been asked what motor do I have. I know that it's the 2.2 Liter.
Does anyone know if a 2005 Saturn Vue motor is one of these?
1. exhaust manifold is drilled & tapped for AIR check valve, EGR port in head
2. exhaust manifold is drilled & tapped for AIR check valve, w/o EGR port in head
3. exhaust manifold is not drilled & tapped for AIR check valve, EGR port in head
4. exhaust manifold is not drilled & tapped for AIR check valve, w/o EGR port in head
Add to srez's Reputation
Rate the quality of this post and help srez reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
srez is offline   Reply With Quote
Old 02-20-2013, 06:56 PM   #2
emsvitil
emsvitil has a spectacular aura aboutemsvitil has a spectacular aura aboutemsvitil has a spectacular aura about
emsvitil's Avatar
Default Re: What type of motor for 2005 Vue
Mine was #4
Replaced it with #3 with a block of plate (#3 was cheaper than #4)
So either 3 or 4 work.
For 1 or 2, see if there's something attached to exhaust manifold
See this thread:
http://www.ecotecforum.com/forums/sh...on-2-2l-ecotec
Post #4 is AIR (not EGR as stated)
http://www.ecotecforum.com/forums/sh...2764-EGR-valve
Ed
Add to emsvitil's Reputation
Rate the quality of this post and help emsvitil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emsvitil is offline   Reply With Quote
Old 02-28-2013, 06:55 PM   #3
youknowme
youknowme is on a distinguished road
who cares? Just swap it for the one on your existing motor...rod knock doesn't ruin manifolds.
Add to youknowme's Reputation
Rate the quality of this post and help youknowme reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
youknowme is offline   Reply With Quote
can replace a type 2 valve body with a type 1?? twincharged S-Series General 0 02-05-2013 08:31 PM
2005 Vue Motor mounts foxbatonrg Vue Tech 7 07-15-2012 08:24 AM
Battery Type Question: 2005 Ion gsgmxm5 Ion Tech 25 12-21-2010 11:55 AM
I need a new window motor - what type.model is it? Admiral Beez S-Series Tech 4 09-23-2009 01:18 AM
What type of Motor Oil do you use in your L Series? Partymmudasti L-Series Tech 34 01-31-2008 09:52 PM
