Old 02-18-2013, 10:25 AM   #1
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
Default Aftermarket fog/driving lights
I'd like to replace the stock lights with aftermarket lights, from what I understand I would need to use a relay so I don't fry the wiring for it. My question is, what wires would I tap to get the aftermarkets to use to stock fog switch? Would I be able to do this without taking anything off in the interior and only being under the hood?
Current:
1999 SC2, 186,XXX
Past:
1989 Mustang LX, Unknown mileage(JY engine in it when I got it)
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 02-18-2013, 12:01 PM   #2
Default Re: Aftermarket fog/driving lights
Run a 10amp (20a? depends on the lights) fused line from the battery (might be easier to use the 7mm bolt for the fuse box, put additions on top so the battery line is in direct contact with the fuse box) to a relay, then the power to the aftermarket lights. Tap into one of the stock fog light wires (driver side is probably easier) to switch the relay on/off.
This way they'll be powered by the battery with new, probably larger than stock, wiring and still work 100% like stock.
Use soldier and heat-shrink for the connections, crimps/quick-disconnects are good for testing and verifying but bad for a permanent outdoor install.
Old 02-18-2013, 12:07 PM   #3
ninetynineSC2
Ok. While we're at it, any recommendations for lights?
Current:
1999 SC2, 186,XXX
Past:
Old 02-18-2013, 02:05 PM   #4
FullNelson13
FullNelson13 is on a distinguished road
Hella Micro DE fog lamps. great, great fog lamp.
Add to FullNelson13's Reputation
Rate the quality of this post and help FullNelson13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FullNelson13 is offline   Reply With Quote
Old 02-18-2013, 02:12 PM   #5
ninetynineSC2
Can you replace the bulbs in the Hellas? I know some lights you can't. And just to make sure I understand this I should use the stock foglight wire only to power the relay?
Current:
1999 SC2, 186,XXX
Past:
Old 02-18-2013, 08:45 PM   #6
FullNelson13
http://www.rallylights.com/Hella_Micro_DE_Wiring.aspx
check that out sir
Old 02-18-2013, 10:25 PM   #7
ninetynineSC2
Thanks for that link. Now I'm actually debating getting both more powerful fog lights AND some driving lights and simply having them side by side, with the fogs operated as normal (with the low beam) and the driving lights wired with the highbeams. Thoughts on this? I'd use relays and wire them either to the UHJB or battery for power.
Current:
1999 SC2, 186,XXX
Past:
Old 02-18-2013, 11:22 PM   #8
FullNelson13
That would work. Just piggy back the high beam wire to switch on a relay for driving lights. so when you want high beams, the new driver lights would come on. Sounds like a good plan to me.
Getting new powerful fogs for normal use is always a good call as well.
Aftermarket Driving Lights, Wiring ?'s Matt95SL1 S-Series Mods 10 02-18-2013 02:10 AM
New Fog/Driving Lights? MeanGreen Ion Mods 2 03-17-2012 08:35 AM
Aftermarket fog lamps/aux driving lights? miataman Outlook General 0 04-15-2008 08:51 PM
aftermarket driving lights SWC S-Series Tech 5 12-05-2005 01:04 PM
wiring for aftermarket driving lights Brendan S-Series Tech 1 10-10-2000 10:27 AM
