Old 02-05-2013, 11:49 AM   #1
rayzur9
rayzur9 is on a distinguished road
Default Steering wheel diagram/exploded view?
Just checking to see if anyone has the relevant manual for the 2003 3.0L V6 AWD Vue, and could post or send the information regarding removal of the steering wheel and horn pad/SIR down to the clock spring? (An exploded view would be great)
I have some of the information such as how to remove it, but was hoping there were pictures or diagrams I can reference if needed.
Any help is much appreciated.
Add to rayzur9's Reputation
Rate the quality of this post and help rayzur9 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rayzur9 is offline   Reply With Quote
Old 02-05-2013, 12:54 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Steering wheel diagram/exploded view?
I can extract those files ... too many and too large to post but I can email. Use PM to send an address if you want.
Old 03-13-2013, 06:45 PM   #3
HawkDriver
HawkDriver is on a distinguished road
Related question: do the two screws on the back of the steering wheel shroud need to be removed before the airbag can be disconnected? I can get the locks to disengage, but the airbag doesn't want to come loose. I feel like something's still attached.
Add to HawkDriver's Reputation
Rate the quality of this post and help HawkDriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HawkDriver is offline   Reply With Quote
Old 04-08-2013, 10:09 AM   #4
rayzur9
Take the top steering shaft cover off. (3 screws thru bottom) to expose the back of the steering wheel better. There are (4) plastic spring loaded catch posts that require that you insert a small flat blade screwdriver and twist, as you are pulling on that corner of the airbag/pad. Mine came off without any additional screws being removed. There are 2 wire connections to the back of the pad, but there is enough wire slack that the pad comes off fully before disconnection of those wires is needed.
Exploded view suspension pics? budward S-Series Tech 2 05-03-2012 01:53 PM
Exploded view 03 brakes Roundthirteen Vue Tech 2 06-23-2008 06:43 AM
Need exploded view of TAAT parts? MichelleG S-Series Tech 0 04-07-2008 07:56 PM
Online exploded view of transaxle? gossimer68 S-Series Tech 0 10-03-2007 10:16 PM
Exploded diagram of spaceframe Newbeak S-Series Tech 14 12-20-2005 06:01 PM
