Old 04-22-2003, 01:19 PM   #1
eljefino
eljefino's Avatar
1995 SW1
Default coil pack won't come off!
I know I'm missing something. The two bolts holding the coil pack on came out just fine, and the pack wiggled around but seemed to be caught on something. The ignition module has this plastic ear on top, above the posts, but it doesn't seem all that springy. Tried getting a screwdriver between there to pry them apart and got to the point of feeling like I was going to break something.
Doing this only to check cleanliness of connections. Car is a 96 SL.
Add to eljefino's Reputation
eljefino is offline
Old 04-22-2003, 01:36 PM   #2
jegster
jegster is on a distinguished road
jegster's Avatar
Default
You may have missed the bottom bolts.
There's 4 bolts total. 2 on the top and the 2 bottom ones.
Jeff
http://www.cardomain.com/id/jegstersl2
Add to jegster's Reputation
Rate the quality of this post and help jegster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jegster is offline
Old 04-22-2003, 03:02 PM   #3
eljefino
eljefino's Avatar
1995 SW1
Default
I'm trying to remove one coil pack of the two, with two terminals, for two cylinders. Two bolts? I did get a bolt from the bottom which was symmetrical to the one on top. I have a feeling there's some sort of clip that held the coil to the module in the factory for that temporary period of time before it was bolted to the car.
eljefino is offline
Old 04-22-2003, 03:41 PM   #4
Scyan
Scyan is on a distinguished road
Default
Yes, the coil is retained in place by two bolts and a clip. The clip is on the bottom but it has to be compressed, squeezed, not pryed. You have to use a pair of pliers or your fingers to squeeze the two pin together and then pull straight and gently on the coil, nothing can really make it stick there unless someone put some glue underneath...
Hope it works all right
Add to Scyan's Reputation
Rate the quality of this post and help Scyan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Scyan is offline
Old 04-22-2003, 04:25 PM   #5
BlackBirdRacing
BlackBirdRacing is on a distinguished road
BlackBirdRacing's Avatar
Default
Just take the entire module out with both coils, it will make your life easier.
Add to BlackBirdRacing's Reputation
Rate the quality of this post and help BlackBirdRacing reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlackBirdRacing is offline
Old 04-22-2003, 08:17 PM   #6
wolfman
wolfman's Avatar
Default
Hey...I was just about to suggest that...and to clean the whole mess while it's out and apart...
Add to wolfman's Reputation
wolfman is offline
Coil pack Keej S-Series Tech 4 01-01-2007 10:12 PM
HesitationÖÖcoil pack? haywood2121 S-Series Tech 5 10-20-2006 06:42 PM
Where to get a Coil Pack? kornphlake S-Series Tech 4 08-31-2006 05:54 AM
Coil pack gmelton S-Series Tech 5 06-22-2006 12:52 AM
Coil pack KJB Vue General 9 08-11-2004 08:16 AM
