Old 01-30-2013, 10:08 PM   #1
bryanr72
bryanr72 is on a distinguished road
2000 SL2
Thumbs Up I installed a VUE cluster & modded it w/blue LEDs
Well, I started off with a Torrent Instrument cluster, but couldn't get it modded with blue LEDs.
The VUE cluster works perfect in my 2000 SL2. I changed the 4 bulbs in back with blue LEDs, and also changed out the odometer light with a blue LED. I used 8.4D bulbs, and had to pinch the contacts a little closer to each other.
Here is my car...everything off. (Daytime)
Daytime, w/the ignition forward.
Daytime, w/the headlights on (low beam).
Night time, w/the headlights on (low beam).
-Bryan
2000 Saturn SL2
5 Speed
116K Miles
Blackberry
Add to bryanr72's Reputation
Rate the quality of this post and help bryanr72 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bryanr72 is offline   Reply With Quote
Old 01-30-2013, 10:34 PM   #2
Speedrc99
Speedrc99 is on a distinguished road
Speedrc99's Avatar
Default Re: I installed a VUE cluster & modded it w/blue LEDs
Lucky, I wish this could be done with 2nd gen clusters
Add to Speedrc99's Reputation
Rate the quality of this post and help Speedrc99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Speedrc99 is offline   Reply With Quote
Old 02-01-2013, 12:17 PM   #3
BobtheTechguy
BobtheTechguy is on a distinguished road
thats awesome, i wish it would fit my 95 sl2
Add to BobtheTechguy's Reputation
Rate the quality of this post and help BobtheTechguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobtheTechguy is offline   Reply With Quote
Old 03-23-2013, 07:12 AM   #4
fjbredt88
fjbredt88 is on a distinguished road
2003 VUE 2.2L
Thumbs Up Re: I installed a VUE cluster & modded it w/blue LEDs
what year of vue did that come off of? it's the same setup as the cluster in my '03 vue, but i like the way that one looks a lot better. i also modded my cluster with blue led's, however my needles turned blue too, i like that you got those one's to stay red...
Add to fjbredt88's Reputation
Rate the quality of this post and help fjbredt88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fjbredt88 is offline   Reply With Quote
Old 03-24-2013, 02:09 AM   #5
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
04-07 white silver on cluster
02-03 has the black only on the cluster
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Add to Saturninin's Reputation
Rate the quality of this post and help Saturninin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturninin is offline   Reply With Quote
Old 05-22-2013, 02:33 AM   #6
foxrunner2099
foxrunner2099 is on a distinguished road
would that fit into a 98 sc2?
Add to foxrunner2099's Reputation
Rate the quality of this post and help foxrunner2099 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
foxrunner2099 is offline   Reply With Quote
Old 05-22-2013, 03:08 AM   #7
Kramer5702
Kramer5702 is on a distinguished road
Kramer5702's Avatar
What about the odometer? I guess you could try to find one close to the same mileage?
2002 SC2 172000 and counting, no oil burning!
Add to Kramer5702's Reputation
Rate the quality of this post and help Kramer5702 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kramer5702 is offline   Reply With Quote
Old 05-22-2013, 03:56 AM   #8
ssewall
ssewall is on a distinguished road
Mileage is stored by the BCM in gen-3s.
Add to ssewall's Reputation
Rate the quality of this post and help ssewall reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ssewall is offline   Reply With Quote
Old 05-22-2013, 11:40 AM   #9
magician22773
magician22773 will become famous soon enough
1997 SL
Great looking mod!
It may just be the pics, but the Odo bulb looks way bright. Not sure if there is anything out there that would be lower output, and still be blue though.
Add to magician22773's Reputation
Rate the quality of this post and help magician22773 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magician22773 is offline   Reply With Quote
Old 05-30-2013, 02:24 PM   #10
rocket321
rocket321 is on a distinguished road
2000 SL2
2002 VUE 2.2L
Anyone else do this? I'm about to purchase the LED's now and wanted to know if I should go with high power LED's or regular ones. I'm also thinking of doing the turn signals, DRL and high beam.
Add to rocket321's Reputation
Rate the quality of this post and help rocket321 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rocket321 is offline   Reply With Quote
Old 05-30-2013, 08:31 PM   #11
Kramer5702
Kramer5702's Avatar
Is this just a straight swap of clusters or does any modifications have to be made? I'm really wanting to try this if I can find a vue at the jy this weekend.
Old 05-30-2013, 08:51 PM   #12
For which car? Presuming your profile is up to date, it's a straight swap with the 2002, and pretty-much impossible with the 1999.
Add to madpogue's Reputation
Old 05-30-2013, 09:06 PM   #13
From 6s, swaps with no other mods: http://sixthsphere.com/content.php/2...series-Only%29
So far, these are what we know work:
03-04 Saturn L-series
02-07 Saturn Vue
Pops a service wrench, traction light may stay on:
05-06 Chevy Equinox
Old 05-30-2013, 10:04 PM   #14
rocket321
2000 SL2
2002 VUE 2.2L
Ordered a bunch of high powered LED's and a regular LED for the odometer. Will post pics once done.
Old 05-31-2013, 04:29 AM   #15
Kramer5702
Kramer5702's Avatar
Where did you order your leds? Are they available in green? How hard is it to switch to the leds?
Old 05-31-2013, 08:05 AM   #16
rocket321
2000 SL2
2002 VUE 2.2L
I ordered them from superbrightleds yesterday. Green is available. I ordered a couple green for the turn signals. The size I bought is 8.4d. Not sure how hard its going to be. From a thread I found and a couple others it seems it can be tricky. I'm on my phone, but if you Google 'the definitive guide to gen3 s series instrument cluster bulb replacement saturnfans.com' that's what I'm going off of.
Old 06-01-2013, 12:52 PM   #17
Kramer5702
Kramer5702's Avatar
Well dang, because of all this I just went out and bought an 05 vue cluster lol, now I gotta figure out if I want leds or not!
Old 06-01-2013, 02:23 PM   #18
Kramer5702
Kramer5702's Avatar
Well, its in, but it threw the wrench light on...ses lights been on cause I had to sell my scanner to find out why. Is there any way to get that wrench off besides black electrical tape?
Old 06-06-2013, 04:42 PM   #19
rocket321
2000 SL2
2002 VUE 2.2L
So the 8.4d's are too small. They do not fit securely in place. Will be sending them back in exchange for the 8.5d's.
Old 06-06-2013, 06:47 PM   #20
Kramer5702
Kramer5702's Avatar
Damn, I wish you would've found out before we BOTH ordered them!!!!
My New Blue Dash LEDs! / Video@100mph burnout Vue Mods 133 03-17-2015 08:06 PM
blue LEDs in dash and gauge lights dragon370 S-Series Mods 11 01-26-2007 11:53 PM
LEDS Installed! FrozenPilot S-Series General 17 10-26-2006 11:14 AM
LEDs finally installed tenn734 Mods and Performance 8 04-19-2004 05:04 PM
Blue Interior LEDs Xanatos Mods and Performance 4 10-21-2002 03:01 PM
