Old 01-14-2013, 08:44 PM   #1
RDO
RDO is on a distinguished road
RDO's Avatar
2001 SL2
Default New TPS, SES still lit - 2001 SL2
SES came on. AZ read codes: p0122 and p0341. Replaced TPS SES still on.
AZ now reads only p0122. Disconnected battery during install & thought that would reset computer. Returned TPS thinking it was faulty. Still have SES with 2nd new TPS.
Can anyone please help? Recommended fix?
Add to RDO's Reputation
Rate the quality of this post and help RDO reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RDO is offline   Reply With Quote
Old 01-14-2013, 10:16 PM   #2
bluesl2
bluesl2's Avatar
Default Re: New TPS, SES still lit - 2001 SL2
Try wiggling the connector on the tps with the motor running and see if it changes idle speed, you may have a wiring/connector problem. For po341, change plugs,wires and make sure the bottom two coil retaining bolts are free of rust on the underside of the bolt head.
Add to bluesl2's Reputation
Old 01-14-2013, 11:50 PM   #3
td1238
P0341 is often set by crossing plug wires 4 and 1, and/or not arranging the wires in an orderly fashion so that they remain in the same sequence from the coils to the plugs. They should be connected from left to right at the coils as viewed: 4,1,2,3. At the plugs it should be 1,2,3,4, as that's the positions of the cylinders as viewed from left to right while standing in front of the car.
Faulty plugs and wires can also set this code.
Add to td1238's Reputation
What to do with my 2001 SL2? MissTraci S-Series General 4 02-24-2012 10:41 PM
2001 SL2 Help winnipegsaturn S-Series Tech 12 02-11-2011 08:15 PM
2001 sc2 help please XxDarkKnightsxX S-Series Tech 19 11-12-2010 06:08 AM
Fs:2001 Sl2 saturnhawaiiguy Classifieds 1 11-08-2002 09:39 PM
2001 L & S oshte L-Series General 7 05-19-2000 10:02 PM
