Old 01-05-2013, 10:34 PM   #1
saturnsctwo
Default 2001 saturn sc2 front bumper support
on a 2001 saturn sc2 has anyone replaced this part:
Bumper/Fascia. .
This fits your 2001 Saturn S-Series SC2 COUPE.
Stock Code 21112623
Fitment Notes
Your Price $ 67.47
Installation Instructions N/A
Additional Notes
Alternate Stock Code
Categories Body > Bumpers
Assemblies Z27 BUMPER/FRONT-ABSORBER, BAR & COMPONENTS;
Manufacturer GM
here's a pic of it on ebay: http://www.ebay.com/itm/NEW-GENUINE-...e372c0&vxp=mtr
if so what's involved? mine is cracked something wacked it i guess. does the front bumper cover have to come off? it almost looks like it can be replaced by pulling it back after disconnecting the 2 push pins underneath on each side, nuts on each side & the center nut holding it in place...
Old 01-05-2013, 11:49 PM   #2
off-track
off-track's Avatar
Default Re: 2001 saturn sc2 front bumper support
Done it?.. no but, from the manual it doesn't look like too much..
That says to remove the bumper cover and then the fascia support. It appears that the support is held to the impact bar by three nuts?
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 01-06-2013, 12:08 AM   #3
saturnsctwo
well i don't want to have to remove the cover. it almost looks like i can slide it out from the back...
Old 01-07-2013, 12:27 PM   #4
I had my kids (ages 11 and 15 at the time) remove the bumper cover on my SC2 as a demonstration to them that cars can be easy to work on
on my '97, there are three 7mm (IIRC) nuts holding the fender liner to the back of the bumper cover on each side, then three push pins in the middle under the hood latch area and some underneath. Twist the light bulb sockets out, push the cover forward off teh support pins. Maybe 15 minutes?
http://www.differentracing.com/tech_...ontfascia.html
Old 01-08-2013, 12:37 AM   #5
saturnsctwo
well the thing is if i take the cover off & it gets twisted the paint will crack. i don't want to get into that. the piece is only cracked on the bottom on one side, really just a cosmetic defect. maybe i will just jb weld it & it will be ok...
Old 01-08-2013, 09:38 AM   #6
bumpdraft
bumpdraft's Avatar
1998 SW2
By all means! If you can rig it in place, do it!
Think how glad you'll be you saved the money the next time you nail something at expressway speeds (1/4 sheet of drywall took out my first facia support).
You could always make an aluminum splice from roof flashing with rivets & backer-washers....all smeared both sides with JB Weld and painted black.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 01-08-2013, 10:40 AM   #7
Hmmm, I guess I didn't really pay attention to my bumper cover paint, as it is kind of cracked from the previous owner, anyway
You can always put some boxes and stuff underneath the cover to keep it from twisting or flexing when you slide it off.
What I did is slide the whole bumper off at the same time, after getting all the fasteners off, rather than getting one side entirely off and lowering it, then moving to the other side. I didn't think it flexed enough to cause the paint to crack (I remember it being pretty strong), but it's been a while.
Old 01-08-2013, 12:26 PM   #8
proveniebam
proveniebam is a jewel in the roughproveniebam is a jewel in the roughproveniebam is a jewel in the rough
I'm a clutz when it comes to maintaining my car but I found it very easy to remove and reinstall without any torquing.
The worst bit was re-attaching to the lining of the wheel arch. Needed to get new plastic bits but instead used self taping screws.
Add to proveniebam's Reputation
Rate the quality of this post and help proveniebam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
proveniebam is offline   Reply With Quote
Old 01-08-2013, 09:29 PM   #9
saturnsctwo
you don't understand. it's only cracked on the driver's side edge. not on any structural area. when ya lay under the car you can see it stick out on both sides & it runs the length of the bumper cover. soemthing on the road jumped up & struck the edge of it & it had a 2" crack in it. i have no idea how that happened without any bumper cover damage. wierd....
Dirt/rocks between rear bumper cover and support? golftango Aura General 6 09-12-2011 10:00 PM
Securing front license plate holder to 2001 SC2 bumper cover David 93 SL2m S-Series Tech 5 07-20-2009 07:52 AM
FS: like NEW saturn evo front bumper. jonnyboy Classifieds 3 04-01-2006 01:54 AM
2001 Saturn L200 Used Front Reinforcement and Front Absorber *Cheap* SuperSaturns Classifieds 0 11-27-2005 03:50 PM
Throttle Body Cleaning & Bumper Support Questions RadioRon S-Series General 18 04-01-2004 04:43 PM
