Old 12-30-2012, 04:24 AM   #1
ggierling
ggierling is on a distinguished road
Default Wire through seatbelt harness help!!!!
Hello,
I am trying to install a Alpine MP-500 amp with a Alpine Type R subwoofer in my 09 Vue.
I have the power wire through the firewall, the RCA, and Remote cable all hooked up. However I got to the point of trying to run the wires through the side panels. I cannot figure out how to either run the wires through the seatbelt harnesses or take off the seatbelt harness panel to get to it.
Can anyone help me please?!
Add to ggierling's Reputation
Rate the quality of this post and help ggierling reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ggierling is offline   Reply With Quote
Old 12-30-2012, 11:41 AM   #2
ProDriver77
ProDriver77 is on a distinguished road
ProDriver77's Avatar
2004 VUE 2.2L
Default Re: Wire through seatbelt harness help!!!!
Haven't done an amp wiring in years, but in the past I usually just pulled up the door sill trim on the bottom of the doors and tucked my wiring under the carpets and trim. As a general rule, I ran the power line down the same side as the battery and the RCAs/remote down the opposite side to avoid interference in the amp.
Hope this helps.
-Matt
SAFETY IN A NUTSHELL: Safety Gear, 2 minutes. Risk Assessment, 5 minutes. A mishap that takes a life: FOREVER!
DRIVE FOCUSED + DRIVE SMART = GET HOME SAFELY!
Add to ProDriver77's Reputation
Rate the quality of this post and help ProDriver77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ProDriver77 is offline   Reply With Quote
Old 01-06-2013, 11:43 PM   #3
ekalb1027
ekalb1027 is on a distinguished road
2004 VUE 2.2L
its a bit tricky..... pull the plastic panel out (gently with a screw driver) straiten out a coat hanger and tape the wires to the end and fish the hanger behind everything through to the other side and get in the back seat and pull it all through...................
thats how i did mine with the wires tucked under the carpet and door trim....
Ps... not sure how different the interior in your 09 is from my 04 sooooo good luck
if your close enough to read my plates then this isnt a race
Add to ekalb1027's Reputation
Rate the quality of this post and help ekalb1027 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ekalb1027 is offline   Reply With Quote
Does anyone know where I can get a new wire harness? Stlrams513 Aura General 0 08-15-2012 03:36 PM
What wire harness to you use? bbslim76 Vue Mods 1 02-01-2009 09:53 PM
Wire Harness yukisho Ion General 6 03-26-2007 09:52 PM
PCM’s and wire harness??? chilson2002 S-Series General 1 08-03-2005 08:31 PM
Wire Harness for an 05' ION-3 QC justskittles Ion General 1 02-27-2005 10:23 AM
