Old 12-23-2012, 11:47 PM   #1
Woody117
Woody117 is on a distinguished road
Dazed 03 L300 no start unless the throttle motor/ throttle body unpluged
Hi all. I've recently received an 03 L300 with the 3.0 it was running fine then it sat for about 2 months while the paperwork cleared. I went back to drive it and it started and idled ok but had not throttle action when I pushed the pedal down nothing then I shut the car off and now the only way the car will start is with the throttle motor/ throttle body unplugged. I noticed with my code reader plugged in to the OBDII plug it will not communicate unless the throttle motor is unplugged. After the the engine starts and drops off of high idle the engine runs very rough as if it is misfiring but I never get a misfire DTC or the SES lamp does not blink during a misfire event. I've swapped the throttle motor/ throttle body with the same results looking for any suggestions on what to check thanks.
Add to Woody117's Reputation
Rate the quality of this post and help Woody117 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Woody117 is offline   Reply With Quote
Old 12-24-2012, 09:13 AM   #2
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Default Re: 03 L300 no start unless the throttle motor/ throttle body unpluged
If I understand you correctly, you have already tried changing the TB for another one you know is OK, and the problem remains. This means that there may be a problem in the wiring or connectors. Look for signs of abrasion or say squirrel gnawing on the wires and corrosion or bent pins in the connectors.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-25-2012, 06:33 PM   #3
Woody117
I have looked at the wire harness and pin fits and I don't see wires damaged. Is it possible that the 5v reference is shorted through a sensor, have you seen that at all.
2002 L300 throttle body? jenjan29445 L-Series Tech 5 06-25-2011 12:15 PM
Throttle sticks - not throttle body - help! dannysm213 S-Series Tech 2 12-10-2006 04:20 PM
throttle body how far? irondiezl3 S-Series Tech 1 11-12-2006 09:40 PM
Rsm throttle body Scottb Ion General 5 11-19-2004 06:13 PM
Throttle Body BadAssSaturnSC2 Mods and Performance 25 05-19-2004 08:26 AM
