Old 12-23-2012, 10:49 AM   #1
ATM
ATM is on a distinguished road
2008 Astra XR
Default Glove Box Door
What keeps the glove box door closed? There's a pull latch on the door but it doesn't seem to do anything and I can open the box by pulling in the corner of the door? Is it magnetic?
Add to ATM's Reputation
Rate the quality of this post and help ATM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ATM is offline   Reply With Quote
Old 12-24-2012, 02:56 AM   #2
smwalker
smwalker has a spectacular aura aboutsmwalker has a spectacular aura aboutsmwalker has a spectacular aura about
2008 Astra XR
Default Re: Glove Box Door
There are two latches that come out from the side on the door. You seeing those?
If you pull the opener they retract.
Add to smwalker's Reputation
Rate the quality of this post and help smwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smwalker is offline   Reply With Quote
Old 12-27-2012, 07:16 PM   #3
ATM
2008 Astra XR
Thanks I see them now.
They move real slow when it's cold outside
Old 12-27-2012, 10:58 PM   #4
Astra08
Astra08 is on a distinguished road
Astra08's Avatar
2008 Astra XR
It is a poor design, I had the same issue. Fixed it by separating the two pieces and replacing with a stronger spring, basically just took the old one and matched up at local auto parts store with something beefier.
Add to Astra08's Reputation
Rate the quality of this post and help Astra08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astra08 is offline   Reply With Quote
Old 11-18-2013, 06:06 PM   #5
wandern
wandern is on a distinguished road
If you're still reading the forum, could you let me know what you had to do to separate the pieces? Did you have to use adhesive to rejoin them, or are there clips, etc.? I had a brief look at mine the other day but it was really resisting coming apart, and I didn't want to break anything.
I haven't had time to look at the problem in any more depth.
Darn car, only 140,000 miles, and it's already had its first problem.
Add to wandern's Reputation
Rate the quality of this post and help wandern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wandern is offline   Reply With Quote
Old 12-03-2014, 12:57 PM   #6
mfedenko
mfedenko has a spectacular aura aboutmfedenko has a spectacular aura about
mfedenko's Avatar
Sorry for resurrecting an old thread but my Mom`s XE is experiencing the same issue, the tabs don't move out enough to engage the holes.
Actually, one doesn't move much at all. How does one access the latch mechanism?
TIA
Add to mfedenko's Reputation
Rate the quality of this post and help mfedenko reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mfedenko is offline   Reply With Quote
Old 12-03-2014, 04:21 PM   #7
Saturn4Ever
Saturn4Ever is a jewel in the roughSaturn4Ever is a jewel in the roughSaturn4Ever is a jewel in the roughSaturn4Ever is a jewel in the rough
Saturn4Ever's Avatar
2009 Astra XR
2008 Outlook XR
Here is another thread where one user took the glove box apart and replaced the spring:
http://www.saturnfans.com/forums/sho...d.php?t=189729
I want to do this as well, but the description of how to open it up is a little vague (could have used a couple more photos).
If I ever get around to performing this "surgery" I'll be sure to post - cold weather is here and with it the season where I dread ever needing to open the glove box.
Add to Saturn4Ever's Reputation
Rate the quality of this post and help Saturn4Ever reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn4Ever is offline   Reply With Quote
Old 12-03-2014, 06:14 PM   #8
mfedenko
mfedenko's Avatar
Thanks for the link, it was helpful. I may do the cabin filter while I`m in there, that looks like fun.
I`ll report back when done.
THX
Old 01-07-2015, 09:47 AM   #9
Astra08
Astra08's Avatar
2008 Astra XR
The poster in the other link provides a pretty good overview of what it takes to disassemble and reassemble. It's really kind of a PITA to take the door apart, but it's been several years since I fixed it, and it's held up fine.
I can only guess this was a replace, rather than repair, design. Terrible.
Old 01-07-2015, 01:26 PM   #10
mfedenko
mfedenko's Avatar
I got around to doing the door repair over the Holidays. The biggest issue encountered as previously mentioned was taking the lid/panel apart.
It`s the kind of thing the designer never anticipated anyone would ever need to access to so it`s all permanently glued together.
I was able to pry the two panels apart by running a very sharp box cutter blade along the mating junctions several times, one side at a time.
Once the bonds are sufficiently weakened by the scribing, you will be able to pry the panels apart.
Finding a higher tension replacement spring with the same dimensions will be next to impossible so you may have to improvise a little. Be careful not to use a spring with too much tension as the tabs they are mated to are barely able to withstand more than what was there originally.
I found a suitable spring at my local big box hardware store but had to cut it down a little as it was too long.
It wouldn't be a bad idea to smother the entire plastic mechanism with white grease either.
The two panels were re assembled with hot glue and they seem to be holding together nicely. There is significantly more retractive tension available on the locking assembly than there was with the original spring.
Did the cabin filter while I was there too, no problems encountered in that department.
Old 01-08-2015, 10:52 AM   #11
Action Jackson
Action Jackson is on a distinguished road
Action Jackson's Avatar
2008 Astra XR
Might as well swap that glovebox light bulb to a less hotter LED. Many of us have melted bulb housings b/c of this randomly opening glovebox.
2016 Honda Fit EX CVT
2008 Saturn Astra XR 5spd (traded)
2000 Acura Integra GS 5spd (SOLD)
2003 Mazda Protege5 5spd (RIP)
Add to Action Jackson's Reputation
Rate the quality of this post and help Action Jackson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Action Jackson is offline   Reply With Quote
Old 02-17-2015, 09:33 AM   #12
e30astra
e30astra is on a distinguished road
e30astra's Avatar
I've pulled the bulb and its being held by tape and Velcro now... So frustrating
Add to e30astra's Reputation
Rate the quality of this post and help e30astra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
e30astra is offline   Reply With Quote
Old 11-21-2016, 08:33 PM   #13
Dartregor
Dartregor is on a distinguished road
2008 Astra XR
In a day or so ill have a good write up with pictures and measurments for all of you guys to help this process along. And yes some sort of adhesive is needed to reassemble. I'm thinking black silicone just incase any leaks out or is visible at the edges. It should also be a little easier to separate just incase i need to take it apart and add yet again a stronger spring. So far my cold weather tests are proving fruitful and i hope will be sufficient for as long as i have the car.
Saturn Astra XR5dr 100k miles-07/031/16
Arctic White
Pano roof
16" OEM rims
Heated Seats
4 Speed Auto :(
Previous cars:
2005 Chevrolet Aveo 4dr(Stick)Sold
1995 GeoMetro 3dr(Stick)Totaled
Add to Dartregor's Reputation
Rate the quality of this post and help Dartregor reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dartregor is offline   Reply With Quote
Old 11-25-2016, 09:59 PM   #14
Dartregor
2008 Astra XR
So as many of you know the glovebox door is of horrible design and has issues with the colder temperatures. So with some guidance from many people who have taken on this task and succeeded.
I started out by removing the glovebox in its entirety which is incredibly easy. Just open the glovebox and there is 4 torx screws around the perimeter. (T15) Towards the end of this adventure I figured out you can take the door off without having to pull out the glovebox.
http://sta.sh/011ywmekrem4
Once those are removed just give the whole thing a slight tug and it will pop out. There is a kind of retention clip in the middle of the top and the wiring for the glovebox light. If your careful you could probably remove this yourself but for me when the retention clip released the glovebox came out with enough force to disconnect itself.
http://sta.sh/0260k23x9p5v
Once removed the glovebox door can be taken off. The door strut comes off easily as nothing is really holding it on and it can be pulled off the peg. Once off if the strut is twisted 90º it comes right out.
The glovebox arms are secured on each side by a single screw and washer, a (T20). Once out the arms can be finagled out of the slots.
Now the fun part begins, splitting apart the door half’s. Someone said that they ultrasonically weld the two pieces together. Either way they are stuck together. Another person said to start towards the top corner which for me was the hardest area. So I started on the bottom/ back corner. I used a 1.5in putty knife to wedge in-between the two half’s and worked my way through the plasti-welds. It is useful to have another person to help pry apart as you work the tool around.
Once separated you are greeted with this. In that upper right (drivers side) corner in can be hard to not muck up the edge plastic but that can be cleaned up with a razor blade towards the end.
http://sta.sh/01mh4yo365uz
http://sta.sh/0xlkdsagkep
Once separated I cleaned up the frilly flashing and got to the door mechanism.
http://sta.sh/0va2k2x54o8
The whole problem is poor grease and what has been described as the worlds weakest retention spring. So I measured the min and max length of the spring and went off to the hardware store in search of something that would work.
http://sta.sh/0hds5x6wdk7
http://sta.sh/023vsw3bvfg2
I ended up buying this which was perfect. A Handi-Pack 5/32 X 15/16 Extension Spring Part#88202.
http://sta.sh/05v6lk7tjbb
http://sta.sh/0pbdc4b98eb
It even fit on it without any modification. By itself it was enough to pull the tabs back out but since it was smaller in diameter I figured it couldn't hurt to use it in conjunction without the original spring.
http://sta.sh/02097zhz4iu
Then I cleaned up the haphazardly schemer of grease with some CLP and worked it in the pivots.
http://sta.sh/026nho2t85p0
Once its all done its reassembly time. I used some black silicone (just incase any squished out I could blend black better than clear). I applied a thick bead on every mark from the plasti-welds.
http://sta.sh/01g7z9eoj2ky
http://sta.sh/0u1iutzjacz
And some squeeze clamps to hold it together while it dries. This is when i figured out the arms kind of click and slide off.
http://sta.sh/0ldvkltav45
http://sta.sh/01zbrje816f7
Then just put it back together and reinstall it back in the car.
Arctic White
Pano roof
16" OEM rims
Heated Seats
4 Speed Auto :(
Previous cars:
Old 03-04-2017, 06:29 PM   #15
daru
daru is on a distinguished road
2008 Astra XR
Thanks for posting this repair, Dartregor Great tutorial - easy to follow & understand for a non-mechie/non-techie like myself!
Recently purchased my Astra, did the glovebox fix last weekend and it's staying closed in colder weather so far. If anyone is in the Calgary, AB area, I have an extra glovebox & upgraded spring to do this fix!
Add to daru's Reputation
Rate the quality of this post and help daru reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daru is offline   Reply With Quote
Old 03-22-2017, 11:26 AM   #16
sirsabre
sirsabre is on a distinguished road
Happy Re: Glove Box Door
Hey daru, I sent you a message, but if you still have the extra glove box, I would love to buy it from you. My door is twisted from the drop open, so I don't think the repair will help. I am in Calgary, so can meet anytime.
Thanks!
Add to sirsabre's Reputation
Rate the quality of this post and help sirsabre reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sirsabre is offline   Reply With Quote
Glove Box Door Handle tiger862 Vue General 1 08-23-2012 03:07 PM
Glove box out???? jgcox6 S-Series General 3 04-18-2009 08:35 PM
need glove box door handle please!!!! 99saturncarboy S-Series Tech 10 08-08-2008 12:20 PM
glove box door stuck Xoss Vue General 1 06-12-2006 02:58 PM
Glove box jay_mil55 S-Series Tech 4 06-08-2006 01:32 AM
