Old 12-20-2012, 02:28 PM   #1
prioris
prioris is on a distinguished road
Default Diagnostic computer codes 301 and 507
Model: 1999 Saturn SL1
Error codes on 301 and 507 on Cylinder 1
Information below suggest replacing manifold gaskets
The defect mentioned below implied the year 2002
Any recommendations
P0507 Idle Control System RPM Higher Than Expected .
Test the IAC valve. Clean it and it's port if it tests out OK.
It turned out to be the intake manifold gasket..was torn in two and allowing air to pass by..causing all my headaches. Thanks a bunch. Debbie
The P301 is a misfire on cylinder #1. the P507 is idle RPM >100RPM above PCM commanded. Those 2 codes together are the symptoms of an original factory defect in installing the intake manifold gasket. When you change it you will find that it has a fold in it right at the #1 Cylinder. Sucks air and leans out #1 so that it will not fire. The additional air runs up the RPM.
Add to prioris's Reputation
Rate the quality of this post and help prioris reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
prioris is offline   Reply With Quote
Old 12-20-2012, 02:40 PM   #2
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Default Re: Diagnostic computer codes 301 and 507
Issue is known for 2000-2002 SOHC engines. Not sure it is common on a 99 model. But, a simple test might confirm. With the engine running at idle, spray a short blast of throttle body or brake cleaner at the junction between the intake manifold and head at the # 1 cylinder (passenger end of engine). If the idle speed changes when you spray, the gasket is leaking.
BV22
2002 SC1 5M
305k 02/18
Add to BV22's Reputation
OBD2 diagnostic codes....? captaintrips S-Series Tech 13 12-08-2012 04:48 PM
Diagnostic codes?? jdb30 S-Series General 4 09-27-2012 02:21 AM
Diagnostic Codes Kessler Vue Tech 3 02-22-2012 05:44 PM
Can someone help w/ my 92 saturn sl 1 and diagnostic codes?! 92teal_saturn S-Series Tech 6 09-09-2010 12:16 PM
Rash of diagnostic codes. Bad computer? byounie L-Series Tech 2 12-29-2008 10:28 PM
