Old 12-16-2012, 02:49 PM   #1
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
Default unused fuse problem?
I was looking for unused fuse locations in the panel in the interior today and noticed I only seem to have one. That one is for the sunroof (which I don't have). I saw two or three other spots that looked like they could have fuses but when I put my test light on them they didn't seem to have power with the key on OR off. (Test light works and was properly grounded). Are they actually spots for fuses or is it something I'm missing? I know one was to the left of the sunroof fuse and the other one/two were above and to the right of the lighter/outlet fuse. Shouldn't those get power?
Current:
1999 SC2, 186,XXX
Past:
1989 Mustang LX, Unknown mileage(JY engine in it when I got it)
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 12-16-2012, 03:19 PM   #2
ninetynineSC2
Default Re: unused fuse problem?
Also, why would I have a fuse in the sunroof spot if I don't even have a sunroof? Does it run something I didn't see in the owners manual?
Current:
1999 SC2, 186,XXX
Past:
Old 12-16-2012, 05:52 PM   #3
If you have power windows then the sun roof is powered from the window relay which is only closed - energized when the key is on so if equipped with either option you got the sunroof fuse. That circuit also feeds the rear wiper and washer in a SW. In your case it is a spare fuse.
Old 12-16-2012, 10:16 PM   #4
ninetynineSC2
Ah. Any ideas why the other empty fuse spots wouldn't have power?
Current:
1999 SC2, 186,XXX
Past:
Old 12-17-2012, 03:16 AM   #5
Gostlrs
Gostlrs is on a distinguished road
1993 SL2
Because the relays or main fuses for them won't be installed in the engine bay. This is true on all the other cars I have owned....Saturn could be different, but normally all the wiring is there for most things & you can install the relays/fuses to get them to work. Since these were kinda made to order back in the day...they might not of installed all the extra things to go with it.
Current Rides
2006 Pontiac Grand Prix
1994 Nissan Hardbody
1994 Mercury Capri XR2 (#350 of 366 Made)
1993 Saturn SL2
Add to Gostlrs's Reputation
Rate the quality of this post and help Gostlrs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gostlrs is offline   Reply With Quote
Old 12-17-2012, 08:51 AM   #6
Because there are no fuse connectors on the pins and/or there is no power circuitry attached to the back pins. There are different wiring harnesses for the major options in these cars, not all cars are wired identically.
Old 12-17-2012, 03:24 PM   #7
ninetynineSC2
When you say no fuse connectors on the pins or no fuses/relays under the hood, would I be able to plug fuses in the empty spots under the hood and in the interior and test again to see if its getting power? When I tried them without the fuse I wasn't sure my test light was able to get far enough in to make a good connection to be sure wether there was no power or it was a connection issue.
Current:
1999 SC2, 186,XXX
Past:
Old 12-17-2012, 06:19 PM   #8
The wiring is probably not there and jamming a test probe into those empty holes can buy you problems that result in spending money.
It is not a matter of plugging in a relay.
Old 12-17-2012, 06:22 PM   #9
That panel is powered from a single continuous power source which is already over loaded and switched power from the ignition switch. There is no unlimited source of toy power inside the car.
So exactly what are you trying to accomplish?
Old 12-17-2012, 10:38 PM   #10
ninetynineSC2
Mainly just curious. Whats on there that makes it overloaded already?
Current:
1999 SC2, 186,XXX
Past:
Old 12-17-2012, 11:21 PM   #11
Everything that is always on except the exterior lights. The various loads are listed in the owners manual. If you do not have one they have many at the pick and pull, just pick up a clean one for your year car.
The major cause of problems is the things that get plugged into the cigarette lighter socket.
Old 12-20-2012, 11:42 PM   #12
ninetynineSC2
Would using the 15 amp sunroof fuse location with an fuse tap to power a few LED light strips cause the F-5 issue or would the fuse blow instead if somehow the lights took that much power? The lights would be switch powered and only on if I dropped something.
Current:
1999 SC2, 186,XXX
Past:
Old 12-21-2012, 12:06 AM   #13
Do you have power windows? If not you will have to install the window relay in the I/P panel and then the Sunroof fuse has power when the key is in run. This is fed from IGN-3. Te hot end of the sunroof fuse is A2 on the 68 pin gray plug on the back of the panel, this is where to pick it up instead of fuse taps. You need to check for wires on A2 as you may have what you need already half installed.
Old 12-21-2012, 12:16 AM   #14
ninetynineSC2
Yep. Got the power windows. Will check for wires behind there. How do you recommend doing that? Just peekin through the other side? Just out of curiosity what would make that location work better than fuse taps? Sorry if these posts seem repetitive
Current:
1999 SC2, 186,XXX
Past:
Old 12-21-2012, 01:45 AM   #15
Fuse taps are ghetto.
Grey plug a is against a long edge and 2 is 2 rows up. might be 2 wires, orange and c-1 is electrically the same spot, single orange wire. The wire at c-1 goes up to the steering column plug. First find out if the wires exist and then where they go can be looked up.
Old 12-21-2012, 11:13 AM   #16
ninetynineSC2
and as long as I have a fuse, LED lights would blow the fuse before it'd cause the f-5 issue (if LED's would even take enough to cause that)? This is what I'm most concerned about.
Current:
1999 SC2, 186,XXX
Past:
Old 12-21-2012, 11:36 AM   #17
That circuit is switched through the ignition switch through IGN-3 and not the continuous switched f-5 circuit.
Old 01-10-2013, 11:18 PM   #18
ninetynineSC2
I was doing some thinking and while ideally I'd run a wire from the battery with fuses and whatnot to accomplish this, hypothetically, would the 15 amp sunroof fuse/circuit be able to power LED lights, a CB radio and another power outlet if they're wired through that to receive power with each device having its own fuse?
Current:
1999 SC2, 186,XXX
Past:
Old 01-10-2013, 11:30 PM   #19
No. Wire a separate stand alone sub panel fed from the battery. Th eLED lights are not a problem, it is the other stuff.
Old 01-10-2013, 11:52 PM   #20
ninetynineSC2
Thats what I figured. Is there any easier/alternative way to get the wire into the car besides going through the wire bundle in the firewall?
Current:
1999 SC2, 186,XXX
Past:
97 sc2 fuse box problem? drumstick1076 S-Series Tech 2 11-09-2011 09:06 AM
help cant find fuse problem scootgal Vue General 2 08-29-2010 01:47 PM
Fuse Problem PurpleSaturn97 S-Series General 1 05-29-2005 01:41 AM
DIS fuse problem jpape S-Series General 6 02-21-2005 11:05 PM
I have an unused QVC coupon... sjt78 General Saturn Discussion 5 04-30-2004 01:51 AM
