Old 12-03-2012, 04:58 PM   #1
Dustineering
Dustineering is on a distinguished road
Dustineering's Avatar
2008 Astra XR
Default CEL Codes
I've had a code for my O2 sensor for a few hundred miles; it goes on and off. Then, yesterday, I went to pass someone and stepped a bit harder on the pedal and just lost power. Pulled off into a parking lot and felt a misfire. I took it in to have all the codes read and this is what I get with a generic description:
P0141 - HO2S
P2A01 - O2 Sensor
P2096 - O2 Sensor
P0136 - HO2S
P0111 - IAT Sensor
P0313 - Misfire Detected
P0301 - Cylinder 1 Misfire Detected
P0300 - Misfire Detected
P0141 - HO2S
Bought some new plugs today to see if that would do anything; it does not. No one around has an O2 sensor, but I doubt that has anything to do with the misfire. Anyone know what I should do?
2008 Arctic White Astra 3-Door XR
-Killed On Impact
Add to Dustineering's Reputation
Rate the quality of this post and help Dustineering reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dustineering is offline   Reply With Quote
Old 12-04-2012, 10:30 AM   #2
vanilla sky
vanilla sky is on a distinguished road
2008 Astra XR
Default Re: CEL Codes
That many codes sounds like something came loose, possibly as simple as a ground going bad. Did you clear the codes?
Add to vanilla sky's Reputation
Rate the quality of this post and help vanilla sky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vanilla sky is offline   Reply With Quote
Old 12-04-2012, 07:08 PM   #3
Dustineering
2008 Astra XR
Coil pack is the issue I guess...ugh.
How legit does this seem?
http://www.ebay.com/itm/Ignition-Coi...0ae8a3&vxp=mtr
-Killed On Impact
Old 12-04-2012, 08:19 PM   #4
vanilla sky
2008 Astra XR
I'd say it's as legit as any other one you're going to find. Their return policy is my only issue. It's also shipping from HK, so it will likely take quite a while to get here.
Old 12-04-2012, 08:35 PM   #5
Tried a spark test with plugs removed and plugged in to the coil pack with plug bases grounded to the engine block? Other than using a reader to check ignition, this may be the only way to test for spark from the coil pack.
How many miles on the car? Any chance the catalytic converter is plugged and causing this misfire and erratic engine issues?
Old 12-05-2012, 03:54 AM   #6
vanilla sky
2008 Astra XR
Oddly enough, that looks like the pile of codes I got after I cleaned my MAF and didn't plug it back in. I had others, but there were a bunch of seemingly unrelated codes tied to that one connection being disconnected.
Old 12-05-2012, 08:33 AM   #7
Dustineering
2008 Astra XR
Yep, that's how we found out it was the coil pack. The car has a touch over 92,000 miles on her now; trip to NY constantly don't help keep her a low mileage vehicle. No emission codes other than the O2 sensor are sent out...but I will see how she acts when all is done.
-Killed On Impact
Old 12-05-2012, 08:42 AM   #8
Well, hopefully a new ignition coil pack is all that's needed to correct all the error codes.
Old 12-05-2012, 12:21 PM   #9
kbg1
kbg1 is on a distinguished road
2008 Astra XE
2003 ION-2 Sedan
report back if this works.
i was going to purchase one for a spare.
keep us informed
thanks
Add to kbg1's Reputation
Rate the quality of this post and help kbg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kbg1 is offline   Reply With Quote
Old 12-06-2012, 05:01 AM   #10
smwalker
smwalker has a spectacular aura aboutsmwalker has a spectacular aura aboutsmwalker has a spectacular aura about
2008 Astra XR
Hey Dustin. You wrote a while ago about upgraded spark plugs: "*I figured an upgrade can't hurt. Plus, 25000 miles per change is a little stupid...way too often."
What did you settle on as a change interval in the end?
Add to smwalker's Reputation
Rate the quality of this post and help smwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smwalker is offline   Reply With Quote
Old 12-09-2012, 12:52 PM   #11
Dustineering
2008 Astra XR
I never hit the mark. I owned the car for about 30,000 miles and then I had this issue. I just tossed new plugs in; didn't fix the issue, but what's done is done .
-Killed On Impact
