Old 11-29-2012, 03:25 PM   #1
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
Default Foglights with highbeams?
Did some forum digging and couldn't find anything about this in the S series forum so here goes
Is there a way to make the foglights stay on with the highbeams? I was thinking about doing the quad headlight mod but I was curious if the foglights can be wired or in some way rigged to stay on with the highbeams. Also, if I would go though with the quad light mod, would the foglights stay on as well?
Current:
1999 SC2, 186,XXX
Past:
1989 Mustang LX, Unknown mileage(JY engine in it when I got it)
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 11-29-2012, 03:59 PM   #2
Default Re: Foglights with highbeams?
It's a 5 minute mod for '95-'99. Remove the shroud around the radio, unplug the switch, then clip the pink wire on the near (driver) side of the plug (viewpoint of it being plugged in & installed). Leave more then enough room to put it back if you decide to undo it.
Maybe it's not a pink wire, but it is on the near/driver side.
Six way headlights when you have lows,highs & fogs on. Should give better search results
Old 11-29-2012, 04:25 PM   #3
ninetynineSC2
When you say shroud do you mean like the cover I'd remove to take out the stereo? Or would it be the fusebox shroud on the drivers side? Also which plug is it? Assuming there are multiple plugs.
Current:
1999 SC2, 186,XXX
Past:
Old 11-29-2012, 04:54 PM   #4
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
Yes, the piece of plastic trim around the radio that the defrost / foglight switch is attached to. And it's all one plug that plugs into there
Add to wi111y's Reputation
Rate the quality of this post and help wi111y reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wi111y is offline   Reply With Quote
Highbeams switching on and off OFC Engine 4 S-Series Tech 2 02-19-2009 09:34 PM
Keeping highbeams on with low beams 2004ep3hatch S-Series Tech 6 11-27-2008 10:29 AM
Highbeams smoking? FGCA_XRL Vue Tech 22 08-27-2008 05:58 AM
Head lights and highbeams... Elementkng20 S-Series General 39 12-02-2007 09:15 AM
Highbeams Black04Ion Ion General 11 12-17-2004 03:50 PM
