Old 11-11-2012, 02:28 PM   #1
trock859
trock859 will become famous soon enough
trock859's Avatar
Default don't buy a Gates thermostat
Here is why you don't want to buy a Gates thermostat.
This is less than 3 years and about 13K miles since I installed it. I hate to think about where the pieces of the seal are wedged.
I replaced it with a Stant, but they looked exactly identical. I wonder if they were from the same manufacturer in China.
This info is probably on here somewhere, but one hint:
Use your 1/4" drive 10mm socket and extension, then adapt it up to a 3/8 drive rachet. The smaller diameter of the socket will allow you unbolt the housing with much less trouble and without taking the hose off. The deepwell socket with a short extension worked the best for me.
I also drained the radiator and engine block for a change of coolant.
Add to trock859's Reputation
Rate the quality of this post and help trock859 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trock859 is offline   Reply With Quote
Old 11-11-2012, 02:35 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: don't buy a Gates thermostat
*yawn*.. Stants will eventually do the same thing; it's happened to me and alordofchaos once.
I believe this is more to do with the design of the stat, not whether or not it was made in China or India or Vietnam or some other communist dictatored country that day (though to be fair it does have some significance..)
1/4" drive ratchet huh? When I tried undoing the t-stat housing using my 1/4 drive ratchet it wouldn't budge.. when I do the thermostat I usually use a 10mm deep well socket hooked to a 3/8" ratchet. with some clever temporary hose stuffing I can free the thermostat no problem.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 11-11-2012, 04:51 PM   #3
The Gates seems to fail sooner though...
Old 11-12-2012, 12:03 AM   #4
Tiger
Tiger's Avatar
I replaced mine with OEM (Made in Germany). They tend to consistently fail before I put 100,000 miles on them. The seal degrades, but is still intact.
Add to Tiger's Reputation
Old 11-12-2012, 02:30 AM   #5
Looks like every single Stant I've replaced in these cars. It's gotta be something with the crap design or crap location.
Old 11-12-2012, 08:24 AM   #6
bumpdraft
bumpdraft's Avatar
1998 SW2
It used to be, anyone sayng Gates failed sooner was fightin' words! Now, it is a sign of end times.
I will stock-up on O.E.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 11-12-2012, 08:48 AM   #7
I thought they were going to be a good part as well...
Old 11-12-2012, 10:03 AM   #8
magtec
magtec will become famous soon enough
1995 SW2
the replacement thermostat i just got from NAPA looked like a cheap piece of crap as well. unfortunately it wasn't priced like a cheap piece of crap. so far it seems to be functioning better than the old one, though. only time will tell.
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 11-12-2012, 01:48 PM   #9
PlasticCarsRock
PlasticCarsRock's Avatar
The NAPA part is exactly the same as the Stant (different box, same exact part from the same manufacturer). Stant is the go-to thermostat for most of us, so that's not necessarily a bad thing, however, the NAPA branded one costs significantly more.
Old 11-12-2012, 02:01 PM   #10
magtec
1995 SW2
yeah. the stant branded thermostat wasn't available same day at any of the local stores, so i got the napa one.
Old 11-12-2012, 02:18 PM   #11
trock859
trock859's Avatar
I was expecting better from them myself.
Old 11-12-2012, 02:20 PM   #12
TXSaturn02
TXSaturn02's Avatar
The 4 year old (I'll have to go check) thermostat I got from Autozone (85 celcius and made in Germany) is still hanging in there.
New owner As of 01/01/18: 225,000 Miles
As of 06/15/18: 49,365 Miles
Old 11-12-2012, 04:53 PM   #13
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
I've had the Stant in my car for over five years and over 60,000 miles. Still going strong.
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Old 11-16-2012, 03:35 PM   #14
manualman
manualman is on a distinguished road
1995 SL
I had a Stant do exactly that in 2 years, around 40,000 miles. IIRC
Japanese Hybrid: $30k, 50mpg: burns Gas + Electric
Saturn Hybrid: $500, 40mpg: burns Gas + Oil
Add to manualman's Reputation
Rate the quality of this post and help manualman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
manualman is offline   Reply With Quote
Old 11-16-2012, 08:45 PM   #15
These thermostats have a design defect in that the turbulent flow past the main disk tends to tear up the seal. As both Gates and STANT build these things in batches by the low bidder every batch is a bit different.
Old 11-17-2012, 10:53 PM   #16
Signmaster
You got at least a few months out of your first Stant unit right?
I do agree that design is probably a larger function of how long they last. The last one I got was the made in Germany unit from NAPA, and is not the same design as the ones that duplicate the Stants.
The sad thing is a cheap and good unit shouldn't be hard to find when dealing with thermostats... we aren't dealing with rocket science here.
Old 11-19-2012, 01:27 PM   #17
manualman
1995 SL
LOL, seriously. Our backup car is my wife's 2003 Honda Odyssey with 200,000 miles on it. Still has the factory thermostat, which functions perfectly. Warms up in 5 minutes in winter, still never overheats pulling our popup camper up Rocky Mountains. Go figure.
Not to say it's a perfect car either. Took me about 10 hours to do the timing belt job on that car. Possibly harder than doing the chain on a Saturn.
Old 11-19-2012, 01:46 PM   #18
I've been kinda using the "what did you do to your saturn today" thread as an online spot for some non-routine maintenance things (in addition to the notebook I keep in the car)
http://www.saturnfans.com/forums/sho...nt#post1817914
Originally Posted by alordofchaos on 12/2/2011
Replaced the thermostat... again. Last replaced on 8/21/2009 at 102,555 miles. Just replaced at 136, 258 miles; had been failing for a month or two when I noticed. So the darn thing only lasted about two years, 34k miles. Stant 14279 both times.
Old 11-19-2012, 02:27 PM   #19
The type of antifreeze has an impact as well on the life of that seal on the main thermostat disk.
Old 11-19-2012, 08:54 PM   #20
magtec
1995 SW2
details?
Gates iPhone app to measure belt wear BobbyP Vue Tech 3 06-17-2012 06:57 AM
02 SL1-which belt with Gates tensioner SL2Many S-Series Tech 1 01-24-2012 10:08 PM
Question about Gates 38112 tensioner fit rickjbr S-Series Tech 4 02-06-2011 08:12 PM
Gates thermostat assembly part # 33911, do not get yzracer14 Vue Tech 8 02-02-2010 10:46 AM
Key holes in lift gates????? illtown Vue General 20 06-03-2004 08:58 PM
