Old 10-31-2012, 09:20 AM   #1
taatman
taatman is on a distinguished road
taatman's Avatar
Default No crank no start, crank and no start
I wanted to post this experience with a 99 Saturn SW2 with over 150k.
My sister had an issue with this car where she would start it when cold, it would idle rough and stall out. Then, it would not restart. If you revved the engine, it would not stall. When hot, there was no issue. It would flood the engine and you could smell the fuel not being burned. I ended up replacing the ECTS and had no issue since. They did call a mechanic out prior and he took off the valve cover, did this and that and charged $125.00 and still no start. The next day, it starts up. This was prior to the ECTS sensor.
Fast forward 4 months later, there is an intermittent no crank no start. At one point, the car was jumped and coincidentally started. Suspects were the factory alarm, possibly neutral safety switch, ignition switch or starter. Cycling through the gears did not help start. So, a test light was used on the starter solenoid and it lit up when the key was turned to start, so it was the starter. A tap of the starter and it fired up. I replaced it with NAPA's $154.00 premium rebuilt starter, no issue yet. When the car was started, the lights did not did and there was no clicking noises under the hood. I'm guessing it was the solenoid, but the starter was original so it was time for replacement. If the starter motor was bad, wouldn't the lights dim?
If you have a no start on your S Series SC1, SC2, SL1, SL2, SW1 or SW2 this might help you out.
Add to taatman's Reputation
Rate the quality of this post and help taatman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
taatman is offline   Reply With Quote
Old 10-31-2012, 09:56 PM   #2
off-track
off-track's Avatar
Default Re: No crank no start, crank and no start
Have you read the sticky at the top of this page?
Also, be sure to look at the youtube posts by richpin06a. He's got a bunch of really useful hints/how-to videos on things just like this.
Used to be that way. These starters don't fail like that.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
98 SC2 No Start/Crank FrankBullitt05 S-Series Tech 4 09-28-2012 05:07 PM
04 Vue 3.5L, Crank No Start 03zq8 Vue Tech 5 08-27-2011 08:46 PM
No Crank No Start My95Sl2 S-Series General 25 03-17-2011 10:41 AM
Crank no start - 01' SL2 comanche S-Series Tech 6 10-13-2009 09:25 PM
96 SL2 Crank but No Start pitch4pd S-Series Tech 18 12-05-2008 08:22 PM
