Old 10-30-2012, 05:26 PM   #1
MeanGreen
MeanGreen is on a distinguished road
MeanGreen's Avatar
2004 ION-2 Sedan
Default Loss of Power and Squeak
So I was on the highway today and driving into a very strong headwind and when I floored it to pass another car I noticed a squeaking noise coming from somewhere on the car and the RPM's just held really high and I wasn't really going anywhere. Upon normal driving, it did just fine, just when I floor it and the rev's build up it seems to lose all power and the squeak noise comes back.
I drove it on normal streets and the same thing happened. Parked it and pulled on the throttle and couldn't hear it, moved under the car and had my friend pull the throttle and I could hear a squeak from the catalytic converter/downpipe area. I've had a CEL on for a long time since I burnt my downstream O2 sensor when I had a misfire, but never had any power issues till now. Am I correct in assuming both my O2 sensors are cooked as well as my cat? I haven't checked to see if any additional CEL's were added, but priced up the 2 O2 sensors and the cat on eBay for about $270, am I fixing my problem with that or is there more I should be checking?
Sorry for the novel, just had to explain it in full.
2004 ION 2 Sedan
-Autozone short ram
-FE5 Suspension with Pedder springs
-4300k Hi-lo HID
-OPTX green underglow
-35% tint all around
-Kicker Audio all around
Add to MeanGreen's Reputation
Rate the quality of this post and help MeanGreen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MeanGreen is offline   Reply With Quote
Old 10-30-2012, 09:56 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Loss of Power and Squeak
Be careful, the cat is integral with the downpipe, and should be replaced as an assembly. You drove around for who knows how long with a bad o2 sensor and misfires instead of fixing them, which very well may have caused more issues. Try fixing what your very is telling you is wrong before you worry about the "new" symptoms
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 10-31-2012, 07:46 PM   #3
MeanGreen
MeanGreen's Avatar
2004 ION-2 Sedan
Yeah I priced up the whole cat/downpipe assembly. I also need a new exhaust manifold gasket as well. Just checking if there were other things that I should check?
Also, does the factory downpipe have a flex pipe in it? I'm guessing that's where the squeak is coming from a leak in it, thus not sending proper amounts of exhaust past O2 sensors, running lean, etc
2004 ION 2 Sedan
-Autozone short ram
-4300k Hi-lo HID
Old 11-02-2012, 08:33 PM   #4
2006 ion2
2007 ION-2 Sedan
I'm trying to remember if the flex pipe is on the downpipe or the cat back, iirc, it's right where the cat back bolts to the downpipe, on the downpipe.
2007 Saturn Ion 2
Old 11-06-2012, 10:24 AM   #5
MeanGreen
MeanGreen's Avatar
2004 ION-2 Sedan
Yeah, checked under the hood when the engine was cold and I can literally spin the outer bit of the flex pipe on the down pipe...I think I found my culprit! Good thing the whole assembly is one pipe, new cat and flex pipe all in one, definitely will solve a lot of problems
2004 ION 2 Sedan
-Autozone short ram
-4300k Hi-lo HID
Monroe Quik Struts - Squeak, Squeak, Squeak simpsondb S-Series Tech 119 07-19-2016 07:47 AM
Power Loss KingRex S-Series Tech 1 08-06-2012 05:53 PM
Power Steering Squeak/Squeal johnakm S-Series Tech 5 06-24-2008 12:25 PM
Power steering pump squeak... erick295 Miscellaneous Tech 1 04-12-2004 02:15 AM
VTi - Loss of power??? tominsky Vue General 22 03-16-2004 10:14 AM
