Old 08-07-2013, 06:58 AM   #21
Madness10
Madness10 will become famous soon enough
Madness10's Avatar
Default Re: Used Oil Analysis Thread for Our Engines.
Originally Posted by sl1driver View Post
I keep thinking I should get a UOA done but I just keep putting it off. Is Blackstone still a decent lab to use?
1 st time using them and they have fast service. They are THE leading analyzer around.
Add to Madness10's Reputation
Rate the quality of this post and help Madness10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Madness10 is offline   Reply With Quote
Old 08-08-2013, 05:10 AM   #22
sl1driver
sl1driver is on a distinguished road
Thanks for the info. I have requested a test kit.
Andy
2000 SL1 5 speed - 149k and still going strong. Slight oil usage.
New Intake Manifold Gasket, Clutch, Ects, Thermostat, IAC, TPS
Add to sl1driver's Reputation
Rate the quality of this post and help sl1driver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl1driver is offline   Reply With Quote
Old 09-04-2013, 08:15 PM   #23
jhonky
jhonky is on a distinguished road
here is my newest one. i changed my valve cover to the gen 1 aluminum kind maybe 1k into this oil....is that probably the reason for the increased silicon? wanted to go 10k but wasn't sure if i should, guess i will next time
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 09-04-2013, 09:47 PM   #24
anmasher
anmasher's Avatar
If the head was exposed to air for a long time then maybe, also if you were rather messy with the RTV that could cause it too.
FWIW - My rebuilt engine had silicon in the 140 range immediately after the build (second oil, first was changed after 30 minutes and not sampled).
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-04-2013, 10:18 PM   #25
jhonky
potentially the latter. shawnv changed my valve cover. head probably was exposed to air for say 1 hour(i had to go to advance to get another gasket since they gave me the wrong one)- idk what is considered messy with rtv, but a few of my spark plug tubes had the rtv stuff on it when i changed them to magnacor
98 SL2
245,000 miles
215/45 17"
Old 09-04-2013, 11:03 PM   #26
anmasher
anmasher's Avatar
I wouldn't worry about it, just make sure it goes down next time. An hour is nothing unless your/his garage is really dusty. Probably just squished out RTV causing it.
Old 09-04-2013, 11:11 PM   #27
Very little RTV will send it right up. What are you using for an air filter?
Old 09-05-2013, 12:02 AM   #28
jhonky
aem sri
98 SL2
245,000 miles
215/45 17"
Old 09-05-2013, 08:29 AM   #29
aem sri
Which filter? Dry flow or oiled?
Old 09-05-2013, 06:36 PM   #30
jhonky
Oh didn't know they had other kinds. I have the dryflow I thought
98 SL2
245,000 miles
215/45 17"
Old 09-05-2013, 07:03 PM   #31
OK, you would know if it was oiled. Those dryflow filters are supposed to be washed every s often. You can buy high priced air filter soap or, you can go to the grocery store and buy a bottle of Woolite soap for washing wool items. Basically fill the sink with cold water and 1 cap of Woolite and slosh filter in it until clean, cold rinse and air dry. No heat! If it has been used for a year or so it will be dirty and pass more dirt which shows up in the oil as silicon. Other than that they are great filters.
Old 09-06-2013, 09:50 PM   #32
jhonky
i bought the aem branded cleaner from their website. how often should i use it?
98 SL2
245,000 miles
215/45 17"
Old 10-30-2013, 09:02 AM   #33
The AEM dryflow is washed in cold water and Woolite if you are cheap. The filter should be cleaned when it is obviously dirty or annually just because.
Old 04-17-2014, 09:29 PM   #34
jhonky
been on my to do list for a month or so. think it's been about a year
98 SL2
245,000 miles
215/45 17"
Old 04-21-2014, 09:48 PM   #35
hunt4steve
hunt4steve is just really nicehunt4steve is just really nicehunt4steve is just really nicehunt4steve is just really nicehunt4steve is just really nice
hunt4steve's Avatar
1993 SC1
Thumbs Up Hunt4Steve 1993 Saturn Oil Analysis Results
Received my results......
Add to hunt4steve's Reputation
Rate the quality of this post and help hunt4steve reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hunt4steve is offline   Reply With Quote
Old 04-22-2014, 04:14 AM   #36
Pitcher
Pitcher's Avatar
Very nice results & the Fe is low for a newly rebuilt engine. Si is a bit high, so check the air filter & airways for any leaks. A quality paper filter or Amsoil EAA filter is a good idea, the K&N's let a bit more dirt in the engine.
The legend is nice to add, but it is old as the Zinc & Phosphorous have been reduced from there on passenger car oil. Good general reference.
'98 SC2 Rare "Red Hot" 5-Speed. Castrol Edge EP
Taking Care of a '01 SL2 10th Ann. Ed. "Silver Salute" Mobil 1 AFE
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-22-2014, 07:32 AM   #37
SL19302
SL19302's Avatar
2002 SL1
This is interesting, There is one oil that I really noticed a difference with engine smoothness and that was with Royal Purple, With the cost of that oil who could afford it though.....
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 04-22-2014, 02:27 PM   #38
hunt4steve
hunt4steve's Avatar
1993 SC1
Funny you should mention the Si, I do run a K&N Filter. Guess I should switch to an Amsoil Ail Filter. This reading was for 10k miles, and using only 1 oil Filter, the Amsoil Ea15k oil filter.
I think I'll get the Amsoil Air Filter and see if the Si numbers are reduced by the next 10 mile mark.
Thanks for the feedback.
Old 04-23-2014, 09:29 AM   #39
hunt4steve
hunt4steve's Avatar
1993 SC1
OldNuc pointed out that the "Universal Averages" that Blackstone uses are based upon a 4k mile oil sample. Since I drove 10K miles, the numbers are a bit skewed when comparing against the "Universal Averages". OldNuc suggested that I divide the Metal Numbers by 2.5 to get a more accurate comparison of numbers against 4k miles.
In doing this, my numbers do drop substantially, which is even better. It should also be noted that I do run a K&N Air Filter. I'll be switching this out to a Wix Filter, which should bring the Si numbers down.
Old 04-27-2014, 08:05 PM   #40
jhonky
does oil go bad? i've had an old gatorade bottle full of oil for like 1.5 months now in my back seat. meant to send it, need the bottles they send
98 SL2
245,000 miles
215/45 17"
Another spark plug analysis thread WarWeasel S-Series General 1 07-04-2011 04:44 PM
Oil analysis - 09 xr VUESBROTHERS Outlook General 4 06-29-2010 09:48 PM
Follow up thread to the ignition key cyl thread Scott Peterson S-Series Tech 3 06-09-2010 07:00 PM
A Look at Oil Analysis for 92 Sl2 stanleyr S-Series Tech 2 05-18-2007 08:08 AM
04 Vue V6, Oil Analysis HomeBase Vue Tech 4 01-06-2005 12:52 PM
