Old 04-16-2003, 06:04 PM   #1
chris_92_sl2
chris_92_sl2 is on a distinguished road
Question Fuel Gauge Stopped Working
Yesterday my fuel gauge stopped working ('92 SL2). It stuck below empty with half a tank and didn't move after I filled up. No other problems (other than a falling headliner).
Any suggestions on where to start?
Add to chris_92_sl2's Reputation
Rate the quality of this post and help chris_92_sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chris_92_sl2 is offline
Old 04-16-2003, 07:19 PM   #2
wolfman
wolfman's Avatar
Default
First things first, CHECK ALL the fuses in BOTH fuse boxes. Don't just look at them, pull them out and MAKE SURE they are good. If they are, open the TRUNK and pull the carpet away from the LEFT side fender well area, you will find a connetor there. Make sure all those wires are connected tightly and uncorroded. Provided all that checks out, you can then either trouble shoot the wire running to the gauge,or you just assume it's the sending unit and drop the tank and replace the fuel pump/sender assembly. You'll need a wiring diagram to trouble shhot the gauge unless someone else has one handy or knows which wire it is...mine is at home.
Add to wolfman's Reputation
wolfman is offline
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 08:07 PM
Fuel Gauge not working, 2000 vue Paddyboy Vue Tech 2 01-13-2009 07:11 PM
Gas Gauge Stopped Working snobrdrdan Aura General 10 05-08-2008 06:17 AM
Fuel Gauge fails / stops working / goes empty while driving?? [Atari] S-Series Tech 3 07-26-2007 11:20 AM
gas gauge stopped working homieg9999 S-Series General 1 09-12-2005 05:44 PM
