Old 10-16-2012, 10:30 PM   #1
TimW
TimW is on a distinguished road
Default Starter Change Causes Speedometer Fail???
I just changed my starter in a '97 SL2 and when I drove it the speedometer was completely gone. Also noticed it would cut out at high RPM's in 1st and 2nd gears. (If I wrapped it out in higher gears it would do it also)
Today on my way to work I got my speedometer back for about 5 minutes but then it wen away again. The car seems to run smooth now.
Pretty sure something happened when I was battling the starter as there was no problem until the starter repair. Any help? Please don't tell be I have to take out the starter again! That wasn't fun!
Add to TimW's Reputation
Rate the quality of this post and help TimW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TimW is offline   Reply With Quote
Old 10-16-2012, 10:57 PM   #2
Default Re: Starter Change Causes Speedometer Fail???
You probably disconnected the VSS. It is located on top of the transaxle right above the axle shafts, straight up. Things will not run right with that signal disconnected.
2007 Installing Remote Starter. Anything I need to get outside of starter package? shaxs Vue General 8 12-25-2011 03:40 PM
Changed Clutch, Starter won't spin/engage (starter clicks) VolvoDude S-Series Tech 10 10-08-2010 01:47 PM
Source for Starter Solenoid / Starter Rebuild Kit acman S-Series Tech 3 04-22-2010 11:55 AM
Easiest way to change the starter? zTagged S-Series General 3 07-02-2008 11:20 PM
Change in tire aspect ratio affect speedometer? conefree S-Series General 12 11-10-2006 11:08 AM
