Old 10-05-2012, 02:20 PM   #1
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
Default Replacement fuel filter?
It's about time for a fuel filter change for the SC2, is there a specific brand I should get? One member of the forums said to only use the Napa/Wix filter or OEM.Why is that? Are there any particular brands to watch out for or can I use any filter? (That is right for the car )
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 10-05-2012, 02:31 PM   #2
Default Re: Replacement fuel filter?
From 98 up, the fuel pressure regulator is integrated with the filter body. Only the OEM filter, the Wix 33731, or the NAPA branded Wix (FIL3731 or something like that), provide the proper fuel pressure.
GK industries makes one that may work, #GF1846 - one member tested one recently, and it provided 1 PSI over
Avoid Bosch, Fram, Purolator... anything other than the recommended filtes, unless you feel like experimenting and the store has a good return policy (and after you've researched what running lean at high throttle does to your valves )
Old 10-05-2012, 02:33 PM   #3
ninetynineSC2
Ok, There's a NAPA not too far away so I'll have to check that one out. I'm leery of giving out my card information online to buy anything otherwise I'd check out ordering the OEM one online.
Old 10-05-2012, 02:36 PM   #4
ninetynineSC2
Tried Bosch plugs once, NEVER AGAIN. I do believe it has a fram oil filter on at the moment and no problems from that. Although it is due for an oil change this weekend if I have the time. Purolator, never tried any of their items and I don't plan on it. My family sticks with the brands we know. Always been that way. But, I ramble
Old 10-05-2012, 07:19 PM   #5
magtec
magtec will become famous soon enough
1995 SW2
purolator makes decent oil filters, actually. i usually use the pureones.
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 10-05-2012, 09:03 PM   #6
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Avoid Bosch, Fram, Purolator... anything other than the recommended fuel filters, unless you feel like experimenting and the store has a good return policy (and after you've researched what running lean at high throttle does to your valves )
fixed
I understand your concern, and would like to happily suggest using PayPal.
There's nothing wrong with Purolator oil filters. I think alordofchaos was only referring to their fuel filters.
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
ruley73 is online now   Reply With Quote
Old 10-05-2012, 09:05 PM   #7
magtec
1995 SW2
was referring to this:
Old 10-05-2012, 10:26 PM   #8
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
There's a place online that sells OEM filters for just over 30 bucks. I can't remember for the life of me what the site is, though. They are listed as NAPA gold, but underneath the Napa sticker is a Saturn part number sticker.
I found the site recommended by another member, so maybe someone will chime in with that old thread...
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 10-05-2012, 11:44 PM   #9
Yes, originally I was only referring to the fuel filters
Since I've owned my Saturn, i have run only one type of oil filter, Purolator PureOne PL20195. I agree with magtec, Purolator makes an excellent oil filter.
Old 10-06-2012, 01:03 AM   #10
ninetynineSC2
Eh. Maybe I'll try them then. I guess my reason for not using them is more of because I just use the brand my family has always used (Now that I think about it, it's fram). I'll have to check and see which filter is cheaper. If it's recommended on here, it can't be bad
Old 10-06-2012, 01:09 AM   #11
ninetynineSC2
On the subject of what brands to avoid, do you guys have any recommendations for plug wire brands and air filters? I was thinking for the wires just go with w/e Napa has available. I already know to stick with NGK copper plugs if I can find them, otherwise just copper plugs gapped properly.
Old 04-25-2013, 01:49 PM   #12
jhonky
jhonky is on a distinguished road
My Saturn has 186k miles and just looked at the fuel filter. 21008019 part number. I pretty much only use shell gas but I think it is time for a new filter. Gonna soak the bolts hardcore before attempting to take them out. Have no idea about drilling new holes and self tapering bolts etc. Got a 5% off rockauto code I want to use
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 04-25-2013, 01:58 PM   #13
colonelhogan44
Get the filter here:
http://www.usafilterstore.com/
It's much cheaper than rockauto.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 04-25-2013, 02:28 PM   #14
For the filter/regulator use a WIX 33731 or the NAPA equivalent.
Do not attempt to remove the bolts. Lift both clips with small screw drivers and push the filter out of the holder while it is still mounted to the frame. It will bend down far enough if you warm it up with a heat gun or hair dryer. Warm before disconnecting lines.
Old 04-25-2013, 04:09 PM   #15
jhonky
dang! just placed my rockauto order too. 2nd time i've had to buy the wix 33731. how is it that cheaper than like every other website? google products, ebay, rock auto...all more expensive. like 80% more than that website. debating on whether i want to cancel the order now...
^thanks oldnuc I may try that way
98 SL2
245,000 miles
215/45 17"
Old 04-25-2013, 04:35 PM   #16
They buy in bulk and probably have minimal overhead. There are several places like that. You end up buying filters by the case to keep the freight cost within reason though.
Old 04-25-2013, 07:12 PM   #17
jhonky
not going to cancel. just take it as a lesson learned(again). i like rockauto, came to 8.18 more in the end after 2.98 shipping and 5% discount
98 SL2
245,000 miles
215/45 17"
Old 04-25-2013, 07:34 PM   #18
That is why I would not get excited about the very low leader prices unless you want a case or 2 of something. Oil filters and transmission filters do not spoil so having a case of 12 is not a huge disaster.
Old 04-26-2013, 08:42 AM   #19
Second time? Hopefully you haven't had any fuel filter failures. Owner's manual says replace every 100k miles (for 98-02) and a lot of people let that slide out to 120~150k with no problems.
OldNu's method works (no surprise ) and it was nice not having to deal with the rusty bolts.
Old 04-26-2013, 09:35 AM   #20
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Anyone put an inline fuel filter in the fuel line just before the OEM one?
Fuel Filter Replacement jacarolan S-Series Tech 2 06-27-2011 12:12 PM
99 SL1 - Fuel Filter Replacement Goliath S-Series Tech 10 04-02-2007 08:25 AM
Fuel Filter Replacement LelandC Ion General 9 11-22-2005 03:17 PM
Fuel Filter Replacement? cpyne S-Series General 6 07-07-2005 10:06 PM
Fuel filter replacement David 93 SL2m S-Series Tech 11 08-13-2003 08:10 PM
