Old 10-04-2012, 03:24 PM   #1
ampecsu
ampecsu will become famous soon enoughampecsu will become famous soon enough
Default Dead Cylinder?
1995 SL2 manual -154400 miles
Possible related history:
Tune up and valve cover gasket ( oil was getting on a spark plug) 2 months ago /car has been burning oil like crazy for past year or so (2 quarts/100 miles) / new egr valve year ago / new catalytic converter 5 yrs ago
other history: New water pump 1 month ago after it failed / junk ac compressor, new radiator cap, new ignition switch
Symptoms:
Past two weeks been shaking at idle (top motor mount failed user "Richpin's" pen test) but shop today said it was ok. / 3 days ago car made a low vibration after shifting into 5 gear. / Car barely takes off in first. / use to blow bluish smoke on acceleration, but now blows a whiter color.
What the shop said today:
Dead cylinder (1st I believe), they took out spark plug that was covered with oil and cleaned it to see if the cylinder would "come back to life" but it did not. Said that the problem was internal and sent me to another shop. They want 60 to diagnose again would not give me a ballpark based on what I told them.
What is you guy's take??? Cost??? What would you do????
Add to ampecsu's Reputation
Rate the quality of this post and help ampecsu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ampecsu is offline   Reply With Quote
Old 10-04-2012, 04:14 PM   #2
bluesl2
bluesl2's Avatar
Default Re: Dead Cylinder?
Do a compression test.
Add to bluesl2's Reputation
Old 12-19-2012, 07:35 PM   #3
ampecsu
Well after driving the car another couple of months it started having trouble getting moving from a stop. After about 5 difficult start-and-get-it-movings, it finally quit at a stop sign on the way to the shop.
They say I need a new engine or a rebuild. They want to charge 900 to swap a motor that I have found.
MY QUESTION is. would a twin cam (dohc) motor from a 1995, model UNKNOW, go in my car no problem.
The engine has 112,000 pulled from a wreck. (so he says) for $500. WHAT IS A GOOD PRICE FOR A SHOP TO SWAP MY MOTOR?
Old 12-19-2012, 07:47 PM   #4
magtec
magtec will become famous soon enough
1995 SW2
a '95 DOHC from any model s-series will be a direct drop-in.
part of the problem with getting used motors for these cars is that unless you are familiar with the vehicle the motor came out of, you can never be entirely sure what you're getting. you seem well versed with the oil burn issue. 112k is pretty low mileage for a '95, and unknown motors are generally better to get from wrecked vehicles if possible (you can be fairly sure it's a runner).
$500 for the motor isn't absolutely terrible. not sure how much it should cost to have a shop install it.
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 12-19-2012, 07:50 PM   #5
ampecsu
the guy said 500 or best offer. I called and just asked some questions about it. I call him back and make an offer if I can find someone to put it in for fairly cheap. Otherwise I am getting rid of it. Its really been a pain in the ass really.
Old 12-19-2012, 07:51 PM   #6
ampecsu
thanks for the answers
Old 12-19-2012, 09:49 PM   #7
off-track
off-track's Avatar
Intimidating at first but, really isn't once you've done it. If you have the tools/place it's a pretty easy DIY weekend project.
If not, check the "services / automotive" section of your local craigslist. I'd bet you could find someone there that would do it for ~$300/400. Ask for references.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 12-20-2012, 09:36 AM   #8
ampecsu
Hey guys, I made some calls and a shop asked me what size the motor, 2.4 or 2.5 I believe. All I knew was SL2, dohc, and twin cam. How do I find this out?
Old 12-20-2012, 09:42 AM   #9
Greg1
Greg1 is on a distinguished road
Greg1's Avatar
1997 SW2
It's a 1.9.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-20-2012, 09:44 AM   #10
ampecsu
Thanks. thats what I figured, but he said that the twin cam had two types while the sohc had one. Maybe I shouldn't go with that shop, huh LOL
Old 12-20-2012, 12:44 PM   #11
Nicktheviperman
Nicktheviperman is on a distinguished road
Nicktheviperman's Avatar
2002 SL1
sounds like a head gasket with the white smoke and blue is oil burning usualy
go on ebay and look at them
Add to Nicktheviperman's Reputation
Rate the quality of this post and help Nicktheviperman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nicktheviperman is offline   Reply With Quote
Old 12-20-2012, 12:48 PM   #12
bobyjones
bobyjones is on a distinguished road
Symptoms:
oo oooo if its not a head gasket do what i did, buy a 400$ saturn on craigslist thats newer and steal the good parts of your old car, itll save you a crapload of money in the long run if you cant rebuild your own engine
i had a 95 that blew a valve suddenly in -7 degree weather because a spark plug was loose(i think)
Add to bobyjones's Reputation
Rate the quality of this post and help bobyjones reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobyjones is offline   Reply With Quote
Old 12-20-2012, 12:52 PM   #13
bobyjones
also if you switch cars make sure you keep the ultra light sawtooh wheels from you 95 if you have em,(95 sl2s had 15inch alloy sawtooth wheels, lightest satirn wheel ever made, i have em, and i love em! they look great on a 99 sl2)
Old 12-20-2012, 03:01 PM   #14
ampecsu
the diagnosis was, was valve and timing chain, something broke inside. something along these lines
Old 12-26-2012, 03:34 AM   #15
ampecsu
ENGINE SWAP!
can anybody refer me to a thread? I going to maybe attempt to swap it myself and I need to know EVERYTHING outside of take out the old and put in they new.
Old 12-26-2012, 08:49 PM   #16
off-track
off-track's Avatar
For the first rebuild we followed these (yes it is a SL1 but essentially the same on any automatic):
Engine Removal Part 1
Engine Removal Part 2
If you lower the engine as much as you can after it's separated from the transaxle you get clearance for the downpipe flange and won't need the prybar like Rich did @ ~4:00.
When it burned a valve a few months ago we just removed the head and TC and left the block in place.
Added OEM CC
Old 01-18-2013, 01:32 PM   #17
ampecsu
They shop replaced the engine but said something was wrong with the timing chain. They told me the found another engine and were putting it in. I gave them a couple of days and called today and they told me they had to put a sensor in and make other changes because they were putting one in from a '98. They didn't tell me they were putting in different model year.
Will this cause problems in the future? Is the 98 engine an oil burner like the 95?
Old 01-18-2013, 01:39 PM   #18
Nicktheviperman
2002 SL1
Typically all saturn engines burn oil after around 80,000 miles of use. 95 to 98 should be able to use the same sensors i belive it changes at 2000 to 2002.
Old 01-18-2013, 01:41 PM   #19
Nicktheviperman
2002 SL1
For some reason saturn didn't put oil drains in so it gets clogged up there and eats away until it lets oil in the cylinders i plan on driving mine till its dead. according to the manufactures every 800 miles 1 quart is okay in there eyes its when you have a problem were your spending more money on oil than you are on gas.....
Old 01-18-2013, 02:01 PM   #20
ampecsu
thanks for the info
Dead Cylinder castblast S-Series Tech 5 06-09-2012 07:06 AM
Dead Cylinder ziggy S-Series Tech 20 02-06-2011 04:41 AM
Dead Cylinder gtst S-Series Tech 2 07-27-2009 05:03 AM
Dead Cylinder! TheDuke S-Series Tech 12 07-21-2005 08:21 PM
Dead Cylinder TheDuke S-Series General 3 07-15-2005 10:42 AM
