Old 10-03-2012, 07:29 PM   #1
twistiert
twistiert is on a distinguished road
1994 SC1
Default Car heats up in traffic
Hey guys I tried to do a search but couldn't really find anything with my same problem. It just started happening one night the coolant light came on but the car didn't over heat. Now in traffic the temp gauge heats up to 3/4 I usually start driving before I can tell if it gets hotter but driving the temp gauge goes back do to 1/4 way. I can't decide if its a temp sensor or the thermostat. Both hoses are full and seem hot. Thanks in advance for the help.
Add to twistiert's Reputation
Rate the quality of this post and help twistiert reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twistiert is offline   Reply With Quote
Old 10-03-2012, 07:34 PM   #2
Default Re: Car heats up in traffic
Start with replacing the ECTS and check the connector for corrosion and the wiring for splices. Correct a corroded connector by replacement and any splices must be soldered and shrink tubed.
Old 10-03-2012, 07:50 PM   #3
twistiert
1994 SC1
Thank You I will try that!
Old 10-03-2012, 08:02 PM   #4
twistiert
1994 SC1
If the ECTS is bad would it still cause temp gauge to raise? I see these cars use two different sensors one for the gauge the other for fan control?
Old 10-03-2012, 08:29 PM   #5
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
Depends on the year. You should put your vehicle information in your profile so we know what car you're talking about when you make a thread.
Add to wi111y's Reputation
Rate the quality of this post and help wi111y reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wi111y is offline   Reply With Quote
Old 10-03-2012, 08:54 PM   #6
twistiert
1994 SC1
O I'm sorry I thought I did it's a 94 SC1
Old 10-03-2012, 10:05 PM   #7
The gauge is the single wire sensor and only provides a signal to the gauge. The fane and cold enrichment is provided by the ECTS, the 2 wire sensor and if it is bad then it will never switch on the fan.
And the short answer to your question is --Yes.
Car heats up at a stop? blue91lx S-Series Tech 7 09-29-2012 09:04 AM
Power window not working when Hot sun heats car murray9 S-Series General 1 06-12-2012 11:36 PM
over heats.. 02satman S-Series Tech 9 06-29-2008 10:31 AM
1997 SL1 Will not heat & it Over heats! saltfishnguy Community Center 5 11-24-2005 03:37 PM
2000 SL2 DOHC heats up Chukaikbi S-Series General 6 10-04-2005 03:49 PM
