Old 10-01-2012, 11:32 AM   #1
Workerbee
Workerbee is on a distinguished road
Default Engine revs at low gear and idle
Help! I have a 2002 SL1 with 120K miles (manual transmission). The engine will rev up and sound "stressed" (inconsistently) in low gears, with idling, and in reverse. Can you give me ideas on what might be causing this?
Add to Workerbee's Reputation
Rate the quality of this post and help Workerbee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Workerbee is offline   Reply With Quote
Old 10-01-2012, 12:34 PM   #2
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Default Re: Engine revs at low gear and idle
Next time is revs at idle, if safe to do so, shut the car off and restart it without touching the gas pedal. If the idle returns to normal, the throttle position sensor is suspect. A 1700 rpm intermittent idle speed is the symptom.
BV22
2002 SC1 5M
305k 02/18
Add to BV22's Reputation
Old 10-01-2012, 01:03 PM   #3
RobertGary1
It can also be a sign that its time for throttle body cleaning, including cleaning the IAC plunger and the seat on the TB it goes into. I've seen cases of both high idle (often idle will come down after 30 seconds or so) as well as initial low idle (idle drops to stop, around 600 RPM, then jumps up to 1000 and then settles) all solved with a good cleaning.
The only reliable way to determine if the issue is a dirty TB/IAC vs a bad TPS is to hook up a computer and read the current "absolute throttle position" percentage that the computer computes. That requires a better than ODBII scanner though. So the easiest solution is to first start with a good TB cleaning. You'll need it either way.
-Robert
Old 10-01-2012, 01:10 PM   #4
ssewall
ssewall is on a distinguished road
Intake manifold gasket leak, almost universal issue on 00-02 SOHCs.
Spray some carb/intake cleaner around the intake header with the car running (preferably cold; carb cleaner is flammable). If the idle dips, you have this problem.
Add to ssewall's Reputation
Rate the quality of this post and help ssewall reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ssewall is offline   Reply With Quote
Old 10-01-2012, 01:12 PM   #5
RobertGary1
Soapy bubbles provides the same result without the fire risk.
-Robert
Old 10-01-2012, 02:32 PM   #6
td1238
Though cleaning the throttle plate is a very good idea, spraying the plate with cleaner often 'fixes' the high idle issue because some of the cleaner gets into the TPS, and masks the worn/dirty condition. Often enough the problem comes back in a while.
If you have a scan tool, observe the TPS reading at idle. It should always be 0%. If it is higher, and you have a high idle, then the TPS is at fault.
Add to td1238's Reputation
Old 10-03-2012, 02:51 PM   #7
Workerbee
Wow - thanks for the quick responses, which made me pay closer attention to the issue. Now I have more to add: the RPMs increase when I press in the clutch, and when I am at a stop light/signal, I will have to let out the clutch and step on the brake pedal to reduce the RPMs to ease up the engine (and stop freaking out the other drivers). Does that change any answers given?
Old 10-03-2012, 04:21 PM   #8
BV22
2002 SC1
If I understand your post correctly, you are letting the clutch drag against the car held still with the brakes in order to keep the revs down? If so, don't do that for long. Again, find a place where you can stop while the car is idling fast and shut it off. If on restart, the idle is normal, the TPS is very likely shot.
If I misunderstood you, and the act of pushing the brake pedal changes the idle speed, then you have a vacuum issue.
BV22
2002 SC1 5M
305k 02/18
Old 10-09-2012, 03:11 PM   #9
Workerbee
You read my second post correctly - I will get it into the shop ASAP. Thanks again for the info!
Engine chirping at idle and low revs mattachuz L-Series Tech 1 07-17-2011 05:20 AM
2002 l200 high idle revs tom_foolery L-Series Tech 2 06-13-2009 10:10 PM
high-ish idle, revs drop slowly between shifts pbarosso S-Series Tech 1 06-04-2008 01:52 AM
1997 SL revs up to 4000 rpms, but will not go from 3rd to 4th gear joffer L-Series Tech 1 04-10-2008 09:47 AM
Idle issue, dies when cold, revs high when warm 93sc2OHguy S-Series Tech 4 12-13-2007 12:24 PM
