Old 09-28-2012, 12:39 AM   #1
blue91lx
blue91lx is on a distinguished road
blue91lx's Avatar
Default Car heats up at a stop?
Hey all,
My 97' SC2 has always ran right at or right above the 1/4 mark on the temperature gauge, regardless if I'm moving or sitting still. Recently, at a stoplight or in a drivethru, the car heats up to a little over 1/2 on the temp gauge. I've started driving before it increases anymore.
Has anyone experienced this? I'm only concerned because it has never done this before.
Thanks!
2003 Mitsubishi Evolution - Fully Built Weekend Car
96' Saturn - Daily Driver, soon to be 24 Hours of Lemons Car
Add to blue91lx's Reputation
Rate the quality of this post and help blue91lx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blue91lx is offline   Reply With Quote
Old 09-28-2012, 01:28 AM   #2
magtec
magtec will become famous soon enough
1995 SW2
Default Re: Car heats up at a stop?
it sounds like the thermostat needs to be replaced. proper operating temperature should have the needle just under the halfway mark (the radiator fan won't turn on until the needle almost hits the red, about 3/4 on the gauge).
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 09-28-2012, 01:59 AM   #3
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Do you know if your ECTS is good?
Do you know the condition of your thermostat?
Have you checked your coolant level?
When was the last time the coolant was changed?
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 09-28-2012, 07:59 AM   #4
DonP
On a '97 expect the temp gauge to sit at about 3/8 scale when on the open road. If the car is not moving and the A/C is off (so the radiator fan is not spinning) the temp gauge will slowly climb to a bit under 3/4 scale at which point the fan should turn on and stay on until the temp gauge drops below 1/2 scale. (The '95 and earlier will go a bit above 3/4 scale before the fan come on.)
If the temp gauge stays at about 1/4 scale or below on the open road the t-stat is likely stuck open and that will result in slow warm up, reduced fuel economy, and slow/weak heat in winter.
On a '96 and newer model year a bad ECTS usually results in inaccurate temp gauge readings (typically low), a variety of driveability issues, and unreliable radiator fan turn-on..
Add to DonP's Reputation
Old 09-28-2012, 08:52 AM   #5
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
is fan turning on?
Add to onefunkar's Reputation
Old 09-28-2012, 02:24 PM   #6
dbsanfte
dbsanfte is on a distinguished road
1999 SW2
This is only a problem if the fan isn't turning on.
Add to dbsanfte's Reputation
Rate the quality of this post and help dbsanfte reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbsanfte is offline   Reply With Quote
Old 09-29-2012, 07:23 AM   #7
blue91lx
blue91lx's Avatar
I do not know if my ECTS is good, however, it's behavior is rather consistent in the manner I described. Once I get a chance this weekend I will check.
Thermostat I was told was replaced not too long ago, but who knows.
I replaced the coolant when I did a water pump last month, and it's still right on the money .
The bolded portion is exactly as I have been describing. The needle sits above 1/4 on the open road (appears to be 3/8), and all of these 'tests' have been done with the AC off. I will let the car run today with and without the AC on to determine.
My Evo had an open t-stat and had the normal symptoms, and the Saturn behaves nothing like that, which led me to believe it was normal. The only reason why it had just started I think is because I stopped using my AC as soon as I started noticing this, (duh, me)
I would've quoted all of you, but multi-quote wasn't working well on my browser it appears. Again, thank you all!
Old 09-29-2012, 10:04 AM   #8
ssewall
ssewall is on a distinguished road
A correctly operating T-stat for 96+ opens at 3/8s(195F, halfway between 1/4 mark and 1/2 mark). A failed T-stat usually opens just a hair above 1/4. Keep in mind this is only when the T-stat opens, it doesn't indicate the temp reading. If you're driving consistently there should be enough airflow through the radiator to keep the temp at 3/8ths. In town there isn't so the temp reading is largely decided by the radiator fan. The PCM uses a hand full of variables to decide when the fan turns on, but generally it comes on around 1/2 for 96+.
Replace the t-stat if it doesn't stay at 3/8ths while driving. Check the coolant system/levels, and whether or not the fan is coming on around 1/2. If both tests pass you're fine.
Add to ssewall's Reputation
Rate the quality of this post and help ssewall reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ssewall is offline   Reply With Quote
Power window not working when Hot sun heats car murray9 S-Series General 1 06-13-2012 12:36 AM
over heats.. 02satman S-Series Tech 9 06-29-2008 11:31 AM
1997 SL1 Will not heat & it Over heats! saltfishnguy Community Center 5 11-24-2005 04:37 PM
2000 SL2 DOHC heats up Chukaikbi S-Series General 6 10-04-2005 04:49 PM
tail/stop/brake lights stop working? (QUICK FIX INSIDE) BLUEION2 Ion General 17 06-21-2004 08:04 PM
