Old 09-26-2012, 06:32 PM   #1
jdb30
jdb30 is on a distinguished road
Default Diagnostic codes??
I have a 95 SL1 that I bought for my daughter. I put it into diagnostic mode and it looks like I am getting back what I think is code #15. The check engine light flashes 1 slow 2 quick for three times in a row, then it flashes 1 slow and 5 quick flashes three times in a row then goes back to the 1 slow 2 quick for three times. Does anyone know what this code means? I couldn't find anything online.
Add to jdb30's Reputation
Rate the quality of this post and help jdb30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jdb30 is offline   Reply With Quote
Old 09-26-2012, 07:35 PM   #2
Chazberry
Chazberry's Avatar
Default Re: Diagnostic codes??
Welcome aboard.
DTC 15 is "Engine coolant temp. circuit. Temp. out of range low"
http://www.differentracing.com/tech_...dtc_chart.html
http://www.differentracing.com/tech_...diag_info.html
You probably want to replace the ECTS (Engine Coolant Temp Sensor)
Add to Chazberry's Reputation
Old 09-26-2012, 10:10 PM   #3
off-track
off-track's Avatar
I'd suggest you start here.
http://www.saturnfans.com/forums/sho...d.php?t=177672
As said, the ECTS. VERY common problem on these engines and really cheap to fix.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 09-27-2012, 12:28 AM   #4
jdb30
I will replace the ECTS tomorrow!!! Any Idea how to reset the diagonistic system to erase the fault code??
Thanks!!!
Old 09-27-2012, 02:21 AM   #5
It'll go away in 5-10 miles, depending on the part the code is for, automatically. Some parts take longer then others to be retested, the ECTS should be within 5 minutes of starting though.
You can speed up the code clearing process by pulling the PCM-B fuse in the UHJB or if you don't care about radio settings you can unplug the battery as well.
Diagnostic Codes Kessler Vue Tech 3 02-22-2012 05:44 PM
Can someone help w/ my 92 saturn sl 1 and diagnostic codes?! 92teal_saturn S-Series Tech 6 09-09-2010 12:16 PM
Rash of diagnostic codes. Bad computer? byounie L-Series Tech 2 12-29-2008 10:28 PM
diagnostic saturanus S-Series General 11 05-22-2005 07:53 PM
92 SL2 Diagnostic?? frogn4u S-Series General 5 01-30-2004 10:23 AM
