Old 09-21-2012, 09:57 AM   #1
grandy
grandy is on a distinguished road
Default SL2 barely runs - EGR?
I've owned 4 saturns, still have an 01 SC2. Never any problems. A friend asked me to help her get her 95 SL2 running. Its the DOHC, and it throbs/pulses at idle. Cuts out like it has a vacuum leak. I swapped the EGR from my SC2, and the symptoms are the same. I've replaced TPS & the coolant sensor. (the coolant sensor had been previously replaced, it has a new connector) From searching the forums, it might be the EGR Solenoid?? If so - where is it?
Any ideas - I'm getting frustrated, not only with the car but with taking my friend to work every day....
thanks for any advice!
Grandy
Add to grandy's Reputation
Rate the quality of this post and help grandy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
grandy is offline   Reply With Quote
Old 09-21-2012, 10:16 AM   #2
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Default Re: SL2 barely runs - EGR?
If I recall correctly, the EGR on a 95 is not the same as on an 01.
DId you check the connection where they spliced the new connector on the ECTS leads?
They are usually just crimped, and should be soldered together.
Alos, the 95 has 2 temp sensors, you sure you replaced the correct one?
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
Add to blue92's Reputation
Rate the quality of this post and help blue92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blue92 is offline   Reply With Quote
Old 09-21-2012, 10:37 AM   #3
1995 was the first year everyone got electronic EGRs; California got electric EGRs in 1994. Not real familiar with EGR issues, but if you suspect the EGR, I think the usual thing test is to block it off and see if the car improves.
In addition to checking the ECTS connector and wire splice, I'd pull the spark plugs and check condition, spark plug wires, and the bolts for the ignition module for corrosion. If you find fouled single platinum plugs, discard and replace with copper core spark plugs.
Was there a precipitating event in the maintenance history (e.g., "it started shortly after I did xx")? Or is it a condition that showed up out of the blue, started gradually getting worse?
Old 09-21-2012, 07:10 PM   #4
grandy
Was there a precipitating event in the maintenance history (e.g., "it started shortly after I did xx")? Or is it a condition that showed up out of the blue, started gradually getting worse?[/QUOTE]
Thanks - checked the CTS wires and soldered them. I tried blocking the EGR - no difference. I pulled the plugs and the two on the passenger side had fresh oil on the threads.....cracked head? I really don't know what precluded the failure; she said that it never overheated.
Old 09-21-2012, 08:30 PM   #5
grandy
Thanks - checked the CTS wires and soldered them. I tried blocking the EGR - no difference. I pulled the plugs and the two on the passenger side had fresh oil on the threads.....cracked head? I really don't know what precluded the failure; she said that it never overheated.[/QUOTE]
more:
I got it to run - sort of. By feathering the gas, i was able to keep it running at high rpm. It pulses there too. once it warmed a bit, it would idle. a minute later it idles good. two more minutes and it cuts off completely. Could the ects connector be responsible?
Passed Emissions - Barely ToastTheRabbit S-Series Tech 3 04-29-2012 02:44 PM
Rough idle... barely runs broman S-Series Tech 10 02-18-2009 04:53 PM
93 Saturn SL 5SPD, Runs stalls... runs Chanman S-Series Tech 1 01-05-2009 05:45 PM
Pics of the 18 that barely clear mad_nigerian S-Series General 26 08-16-2007 03:44 PM
A/C barely cold- mechanic says theres nothing to fix acr2001 S-Series General 19 09-29-2005 11:29 PM
