Old 09-18-2012, 05:58 AM   #1
jchu210
jchu210 is a jewel in the roughjchu210 is a jewel in the roughjchu210 is a jewel in the roughjchu210 is a jewel in the rough
jchu210's Avatar
Default Codes P401 and P405 - EGR ??
Hi all,
just got out of a P341 code simply by replacing the wires.
Now all left to do is get rid of P401 and P405.
some things i did..... took out egr valve, cleaned it
started car without egr attached in order to blow the carbon out
some things i noticed i did not do....
clean egr passage.... wouldnt know how ...
and replace egr gasket.... i cant tell whether or not i am suppose to replace it.... or even how to replace it if its stuck on a part.... (scrape it?)
and more.... dont know much about this topic
thank you all in advance for reading and helping with suggestions, really appreciate it.
99 sc2 1.9 dohc
Add to jchu210's Reputation
Rate the quality of this post and help jchu210 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jchu210 is offline   Reply With Quote
Old 09-18-2012, 10:34 AM   #2
Default Re: Codes P401 and P405 - EGR ??
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
Search threads about these two issues and whether or not the egr valve is faulty. No cleaning in the world will fix a broken feedback sensor but a sticking pintle valve can benefit from cleaning. If the engine runs fine then the egr valve electronics and/or motor failed.
Old 09-18-2012, 05:23 PM   #3
jchu210
jchu210's Avatar
wait a sec.... did u say motor fail ????
.... what does that mean !!
Old 09-18-2012, 05:40 PM   #4
Your egr valve is an electric one, using stepper motors to move the pintle valve. The feedback sensor is electronic and senses pintle valve position that's sent back to the pcm to tell the pcm what position the pintle valve is in.
Old 09-19-2012, 06:43 PM   #5
jchu210
jchu210's Avatar
so i cleaned the egr again, blew out the passages again, still code 401.
am i right to go to junkyard to get the replacement egr valve??
fdryer thank you btw
Old 09-19-2012, 06:53 PM   #6
Yes, just remember there's no guarantee that a used one will work.
Code P405 rockermikey S-Series Tech 9 04-04-2012 12:57 PM
P401 code will not go away Whiplash7x S-Series Tech 2 10-15-2010 06:31 PM
Codes 341 and 440 PiercedOne S-Series Tech 2 10-26-2008 08:17 PM
Got my codes read.. the autozone rep was surprised to see soo many codes... oh no bskicrash1 S-Series General 2 11-12-2006 01:10 PM
SES Codes (beyond the paperclip codes) rkhassen S-Series Tech 11 10-18-2006 07:53 AM
