Old 09-16-2012, 05:03 PM   #1
CaliChuck
CaliChuck is on a distinguished road
Default Autozone Fuel Filter
Will a fuel filter from auto zone work fine? I know dealership is always best but Im a student and dont have alot of cash.
I have a 1999 Saturn. Where is it located? Im reading its next to the tank in the back, is it hidden away or easily accessible?
Add to CaliChuck's Reputation
Rate the quality of this post and help CaliChuck reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CaliChuck is offline   Reply With Quote
Old 09-16-2012, 05:28 PM   #2
Default Re: Autozone Fuel Filter
Go to RockAuto and buy a WIX 33731 which is what they generally list for Saturn. It is cheaper than the dealer and it will work. Do not try anything other than a WIX or OEM.
http://www.rockauto.com
Use this discount code.
111797488928692
Using Your Discount Code
Enter the code above in the "How did you hear about us" line of the shopping cart.
Old 09-16-2012, 07:04 PM   #3
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
111797488928692
^^ Trust this advice.
I made the mistake of installing another name brand (premium) filter on my '02 SL1. It started throwing codes as soon as I installed it. 'lean mixture' or something like that.
Go with Wix or OEM only.
Add to caveeagle's Reputation
Rate the quality of this post and help caveeagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caveeagle is offline   Reply With Quote
Old 09-16-2012, 07:17 PM   #4
dakota1820
dakota1820 will become famous soon enough
2002 SL
i am not going to say the autozone wont work but if it did work you would be one of the lucky few. i would only use wix i used purolator and my car ran rich slapped a wix on and all is good
Add to dakota1820's Reputation
Rate the quality of this post and help dakota1820 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dakota1820 is offline   Reply With Quote
Old 09-16-2012, 07:22 PM   #5
magtec
magtec will become famous soon enough
1995 SW2
this cannot be emphasized enough.
your fuel filter has a built-in regulator. the cheaper aftermarket filters are notorious for having faulty regulators... if you're lucky you'll merely have starting problems or it'll run rich, if you're unlucky it'll run lean and burn exhaust valves (permanently damaging the motor).
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 09-16-2012, 09:16 PM   #6
CaliChuck
Ok. Ill get the WIX. its 5 bucks more. But where is it located exactly?
Old 09-16-2012, 10:02 PM   #7
caveeagle
caveeagle's Avatar
You can also get the NAPA version that is made by Wix
Old 09-17-2012, 04:30 AM   #8
PlasticCarsRock
PlasticCarsRock's Avatar
http://www.youtube.com/watch?v=lVeyA6B2afU
Old 09-17-2012, 10:15 AM   #9
What symptoms are you trying to resolve with the new fuel filter?
the factory recommends replacing it at 100k miles, but most people don't have problems through roughly 150k miles.
If you are trying to save money, troubleshooting by replacing parts is not the way to go
It's entirely possible your symptoms might be caused by something other than the somewhat pricey fuel filter, e.g., ECTS, etc
Old 09-17-2012, 12:02 PM   #10
CaliChuck
Okay but the video doesnt point where it is? I have bad hearing sorry.
When I press gas pretty well it chokes for a bit but once RPM gets higher then it flows like butter. I am certain its the fuel filter because I have a 91' S10 Chevy that did practically the same thing, If you're easy on the gas, it's fine, but push the pedal mid level it will choke then kick in.
Old 09-17-2012, 01:12 PM   #11
It also my be your plugs. Are you using NGK BKR5ESA-11 plugs? The filter/regulator is just in front of the left rear tire, up beside the tank.
Old 09-17-2012, 02:58 PM   #12
OHCPower
OHCPower will become famous soon enough
OHCPower's Avatar
What? Mine was underneath the firewall by the front left tire.
Add to OHCPower's Reputation
Rate the quality of this post and help OHCPower reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OHCPower is offline   Reply With Quote
Old 09-17-2012, 03:06 PM   #13
1991-1997 location is where yours is, and the filter selection is not critical since it used a separate pressure regulator.
1998-2002 has the filter location where OldNuc mentioned and filter selection is important as many/most aftermarket makers do not provide the proper pressure.
Once you get the car up, it's pretty easy to locate. You do not need to unbolt it, either. The black plastic holder will bend enough to get it out/iin as long as you are careful and go slow.
But try plugs or whatever else OldNuc recommends first. Plugs should run about $10 total (or less w discounts) vs $60 for the filter. There are several things that can cause the bogging - another possibility is the ECTS but that usually has other symptoms (hard starting, poor mpg, low temp gauge reading, black smoke from exhaust)
Old 09-17-2012, 03:19 PM   #14
OHCPower
OHCPower's Avatar
I see. Sorry for the confusion.
Old 09-18-2012, 08:40 AM   #15
No worries - it's how we learn
I've asked my share of the same questions... sometimes I have to copy/paste the info into a document in my hoard of Saturn knowledge, to keep track of it all. I'm pretty well set to own any year S-series, though most of my info/experience is in 2nd gens
Autozone trans filter dissasembly Daveg97 S-Series General 2 11-21-2011 04:25 PM
autozone VS Wix fuel filters?? airon1974 S-Series Tech 8 01-18-2011 08:04 PM
Does Autozone Trany filter cause whine or other trany noise? rtfm17 S-Series General 11 11-18-2007 01:15 AM
fuel pumps from autozone? kmwas S-Series Tech 2 01-22-2006 09:32 AM
Fuel injector? Fuel filter? Air filter? LoveMySaturn Miscellaneous Tech 13 05-14-2004 09:14 PM
