#1 | ||||
![]() Join Date: Jul 2012
2005 VUE Red Line
I bought a warranty on my used RL which will cover the timing belt...but since you supposedly cannot tell when it is wearing out....how do you get the shop to change it under the warranty because you know they are going to say that it doesn't need changing (I mean who wants to do that for free?) and use a lame excuse of how it doesn't look worn....
#2 | ||||
![]() Join Date: Aug 2010
I would imagine that any third party warranty like that wouldn't cover routine timing belt maintenance/replacement. Instead, it probably covers premature failure. So either figure out a way to make it fail and grenade your entire engine or just buck up and pay for the routine maintenance (i.e. preemptive replacement) at the correct interval.
#3 | |||||
2005 VUE Red Line
#4 | |||||
Your warranty is what's generally considered a third-party warranty (i.e. non-manufacturer). Without reading the contract, it's going to be difficult for any of us to give you usable advice. I highly, highly doubt it's worded in a way that truly includes replacing the timing belt or other routine/scheduled maintenance.
#5 | ||||
Timing belt service is usually just based on the mileage on the vehicle. There's no "it's going out" discussion. On your VUE, I believe the interval is every 100K (or maybe 110K) miles. I doubt any warranty company is going to cover routine maintenance though...any more than they'd cover brake pads or oil changes.
Best, ... Josey Wales: When I get to likin' someone, they ain't around long. Lone Watie: I notice when you get to DISlikin' someone they ain't around for long neither.
#6 | ||||
![]() Join Date: Mar 2010
2004 VUE 3.5L
Exactly, the timing belt is considered a consumable or wear and tear item. I changed mine out at 120,000 miles and it still had loads of life left. Any mechanic should be able to pull the cover off and inspect it for cracks.
... 2004 Vue 3.5L AWD
#7 | ||||
2005 VUE Red Line
Right, not for maintenence but I truly think it may be stretching......because I honestly do not think the shifting is on point. I will see how well she runs after changing the transmission fluid this weekend......
#8 | |||||
![]() ![]() Join Date: May 2009
2004 VUE Red Line
I agree with the others, unless it's a service contract that covers routine upkeep and scheduled items, they're not gonna cover it. And even then, since you're past the time it should be done, they likely wouldn't cover it. And as an aside, if the belt breaks and trashes the engine they won't cover repairs to the engine without proof that the belt was replaced, as they will (rightfully) say you were negligent in not performing the routine upkeep on the vehicle. That said, the Honda tranny is fairly resilient and responds well to having the fluid drained and filled a few times.
#9 | |||||
2005 VUE Red Line
#10 | |||||
Further, if you're having shift issues with the Honda V6/transmission combo, it's a common problem with absolutely nothing to do with the timing belt.
#11 | ||||
2004 VUE 3.5L
I'm never heard of a stretched timing belt, maybe a timing chain, but belts usually rip apart before they stretch. If your belt did stretch it would be because of an aggressive aftermarket cam, not the stock Honda one.
If your tensioner failed or if your belt really did stretch, you would be noticing the engine running rough and backfiring.... In addition to the check engine light. I would post a video showing your transmission issue. ... 2004 Vue 3.5L AWD
#12 | |||||
2005 VUE Red Line
Well....if you look under the thread about timing belts breaking "RedGeminiPA" and "RobertGary1" both mention the honda dealership said that it could stretch affecting the timing and possibly emissions. This truly makes more sense because of totality of parts that are damaged when it breaks and the fact that it doesn't really show a lot of wear and tear to forwarn you that its going to break soon. Now I don't know one way or the other since I only know from what I read on here :-) However, I will find out more when I go into the chevy dealership and inquire about believing I have a timing belt issue...I will update the forum with any new recommendations I receive so you can let me know if he knew what he was talking about lol
#13 | ||||
A timing belt can affect the timing? No way!
Timing =/= shift timing.
#14 | |||||
2005 VUE Red Line
#15 | |||||
2004 VUE Red Line
But hey, you're entitled to believe what you want. Just remember, warranties have clauses saying that you need to follow and prove that you followed the maintenance schedule. Even from before you owned the vehicle. Even factory warranties will do this.
#16 | |||||
... Avid Apple, car and vacuum enthusiast. Don't hate! ;) Current: '04 FWD 3.5L Previous: '05 AWD Red Line '02 L200 http://www.facebook.com/SaturnFansNorthEast
#17 | |||||
#18 | |||||
2005 VUE Red Line
#19 | |||||
2005 VUE Red Line
#20 | ||||||
Second, the person you told off is one of the people you were using as a reference above. See: Quote:
The timing belt influences engine timing ONLY. Has zero to do with shift timing. I wish you'd actually try to think things through before arguing.
| Thread Tools | |
| Display Modes | |
| 3.0 Timing belt change NEED HELP! | steven_1104235 | Vue Tech | 4 | 02-25-2012 09:48 AM |
| When to change timing belt on LW? | wwilson | L-Series Tech | 6 | 02-05-2011 03:04 PM |
| L81 Timing belt change | jrm1493 | Vue General | 16 | 06-27-2009 12:48 PM |
| When to change timing belt? | Jinjo | S-Series Tech | 2 | 05-09-2006 02:39 PM |
| Timing belt change? | rongeur | S-Series Tech | 18 | 04-26-2002 01:23 PM |
