Old 09-02-2012, 02:55 PM   #1
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
Default Replacing DEX III with ATF+4
I've read a bunch of other fourms where people have been substuting ATF+4 for DEX III.
What are your thoughts? Its synthetic, and has all but the same weight as DEX III (SUS and CST wise at 100C) only difference seems to be what friction modifiers are in it compared to DEX III.
Old 09-02-2012, 05:57 PM   #2
amazinghl
Default Re: Replacing DEX III with ATF+4
ATF +4 is a Chrysler spec fluid, I wouldn't put that in a GM trans.
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
Old 09-02-2012, 06:17 PM   #3
A full synthetic universal ATF is ATF+4 compatible as well as Dex 2 and 3 compatible. The Generic Chrysler ATF+4 is not backward compatible with Dex 2 and 3 however unless so marked on the package.
Using an ATF marked as ATF+4 does not guarantee Dex 2 and 3 compatibility though.
Old 09-03-2012, 05:49 AM   #4
adventureoflink
adventureoflink's Avatar
yeah really, not to mention Chryslers need stickier fluid, this is where ATF+whatever comes in. Our transmissions don't need fluid as sticky, hence why we use Dexron (preferably III in this case).
and don't think about putting ATF+whatever in a Ford trans either..
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 09-03-2012, 10:02 PM   #5
autopat
autopat is on a distinguished road
1996 SC1
With the track record of the Chrysler transmissions, I think I'd pass on that one! You never know, maybe it has something to do with their "unique" fluid.
2010 Camaro SS
2000 Suburban
1998 SL1
1992 Monterey Cobra
1990 Suburban
1973 Nova SS
1966 Suburban
1965 Chevy S/W/BW
So many projects....so little time!!
Add to autopat's Reputation
Rate the quality of this post and help autopat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
autopat is offline   Reply With Quote
Old 09-04-2012, 12:16 AM   #6
magtec
magtec will become famous soon enough
1995 SW2
actually, the "unique" fluid was designed to fix the problems that the a604 4-speed automatic had with dexron.
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 09-04-2012, 06:31 AM   #7
1996SL11.9L
2002 SL1
Actually my 1994 cummins has 160,000 miles behind my foot. It's had either Pennzoil multi vehicle or ATF+4 it's entire life. Mostly the Pennzoil though. It still will chirp tires shifting into 2nd.
I use the Pennzoil in the satty.
Old 09-04-2012, 07:36 AM   #8
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Actually most of those issues were driveabillity issues, bump shift, and erratic shifting. For the most part the units were not "blowing up". This was due to the unique way clutch volumes were measured and pressure was regulated. Especially with the torque converter having the ability to partial lock. Dexron just did not behave well and caused shuddering.
Odds are using ATF+4 in a GM trans would most likely result in no issue maybe even behaving better. But bottom line the Chrysler units were not the dogs they were made out to be. I personally know of many of them that were replaced because the service manager "said to". Once they (Chrysler) got the fluid formulated well and got away from a couple seal designs that caused the bump shift they are really very good units
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
Old 09-05-2012, 06:22 AM   #9
1996SL11.9L
2002 SL1
I love the 545RFE in my 2004 Grand Cherokee. I just wish it locked up the TC every shift like the Saturn. Also wish it stayed locked up on decell like the Saturn.
The A999 in the 86 CJ7 has 160,000 on it also. I had it gone threw at 120,000 when I replaced the engine. They said the clutch plates still specked out to new. So all they did was replace bushings and seals.
I also wish I could figure out the PID address for the grand cherokees trans temp like I found it in the satty for my scangauge.
Need some help replacing my cat. Maroon97SL S-Series General 15 06-07-2011 06:15 PM
Replacing my 95 SL1 - Thank you for all your help! kkspeed S-Series General 0 04-25-2009 02:36 AM
Replacing Tie-Rod End quickster S-Series Tech 7 04-24-2008 08:21 PM
replacing front brake pads on 2002 L-200 requires replacing rotors? UserName L-Series General 12 12-29-2004 12:28 PM
Replacing EGR with used.. BuzzStPoint S-Series Tech 7 09-17-2004 08:05 PM
