Old 08-31-2012, 12:43 PM   #1
Motoboy10
Motoboy10 is on a distinguished road
Default A/C Interior Water Leak Solution
So lately I began to have wet driver and passenger side front carpet in my 1995 SL1. The floor mats were wet underneath and not on top. After searching a bunch on here I figured it had to be my A/C evaporator outlet drain was clogged, since I don't have a sun roof. I cleaned the drain as instructed, ink pen trick, but my floors were still getting wet. I noticed water dripping inside below the evaporator housing so I knew it was the A/C. The drain was wide open but it was still coming inside. I remembered I had the same issue when I had a '92 Grand Marquis that when the water drained out of the evap drain it would drip down and hit a foam insulator that went around the drain between the evap box and the fire wall. The water would hit the foam, which deteriorated over time, and would run back inside the car. Well that is what is happening here. Water ran out of the drain and back into the car. Solution was to put RTV around the drain where the foam is and, as an added precaution, I also stuck a small piece of 5/8 rubber hose, about an 1 1/2 long, off the end of the drain to extend where the water runs out to make it further from the fire wall. Result is no more water inside my car. Hope this help someone.
Add to Motoboy10's Reputation
Rate the quality of this post and help Motoboy10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Motoboy10 is offline   Reply With Quote
Old 04-19-2013, 10:35 AM   #2
whoodiestyle
whoodiestyle is on a distinguished road
Default Re: A/C Interior Water Leak Solution
I'm going to try this cause mine does the same thing 95 sl1
Add to whoodiestyle's Reputation
Rate the quality of this post and help whoodiestyle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
whoodiestyle is offline   Reply With Quote
Old 04-19-2013, 11:06 AM   #3
Highmile
Highmile's Avatar
Mine just started it as well...
Highmile
'95 SL1 513k and counting
Highmile
95 sl1 496k (rebuilt engine)
Add to Highmile's Reputation
Old 04-19-2013, 03:17 PM   #4
Motoboy10
Give it a shot. On a nice day you may want to take the carpet and seats out to let everything get good an dry, its not too hard.
I'm about to hit the 200k mile mark myself, love the car.
SW2 Water Leak Brendo613 S-Series Tech 5 02-17-2015 03:23 PM
Interior water leaks Smee Outlook General 10 07-21-2014 11:22 AM
Saturn 2002 SL1 - Bad Interior Water LEAK!! fretese S-Series Tech 10 12-23-2011 01:30 AM
Major interior water leak...HELP!!! duanejen Vue Tech 10 11-04-2009 11:49 AM
Water leak = HUGE need solution for damage SL2Dreams S-Series General 5 10-04-2003 12:45 PM
