Old 08-31-2012, 12:37 PM   #1
davemanuel
davemanuel is on a distinguished road
Default 2002 Saturn SL1 Trouble codes
Hi,
The following trouble codes showed up on my daughter's car yesterday :
P0341 camshaft position sensor - I cannot find this sensor on the cylinder head - any idea where it is located ?
P1404 EGR valve position - can I clean the valve pintle/shaft , or do I have to replace the complete valve ?
U1300 code - does anyone know what this code means - I cannot find it in my Haynes manual.
Any help/suggestions would be greatly appreciated. Thanks. - Dave.
Add to davemanuel's Reputation
Rate the quality of this post and help davemanuel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davemanuel is offline   Reply With Quote
Old 08-31-2012, 12:53 PM   #2
Chazberry
Chazberry's Avatar
Default Re: 2002 Saturn SL1 Trouble codes
No Cam - Crank . . .
http://www.youtube.com/watch?v=PVTFFOwqNZM
http://www.youtube.com/watch?v=bt5lRTt6BsU
http://www.saturnfans.com/forums/sho...ighlight=U1300
Add to Chazberry's Reputation
Old 08-31-2012, 02:10 PM   #3
Originally Posted by Chazberry View Post
WRONG! Or the wrong right, at least ("you are in a helicopter"....). True, our cars do not have a cam position sensor. But the P0341 code has NOTHING to do with the crank position sensor. This is a favorite for the auto parts stores; they scan, find a 340 or 341, and sell you a part you don't need and that doesn't fix the problem. To generalize - the sensor or part referenced in a particular trouble code is NOT necessarily the sensor or part at fault. It's simply the one _reporting_ the fault. Simply replacing the referenced part is equivalent to shooting the messenger, but auto parts stores still like to do it, for obvious reasons.
To diagnose a P0340 or P0341 on a car without a cam position sensor like ours, make sure the spark plugs and wires are in good shape, and DO NOT use any fine-wire spark plug, such as the typical platinum or iridium plug. Also make sure the grounds for the coils and ignition module are clean, and don't let the spark plug wires touch each other.
Add to madpogue's Reputation
Old 08-31-2012, 05:44 PM   #4
Chazberry
Chazberry's Avatar
Originally Posted by madpogue View Post
WRONG!
Thx for the correction mad.
saturn L300 trouble codes P0700 & P0727 kssbss L-Series Tech 14 07-10-2017 12:23 PM
2002 Saturn L100 running rough and trouble starting frankmassa L-Series Tech 5 02-04-2012 06:06 PM
93 Saturn SL1 Trouble Codes SaturnSky S-Series Tech 1 11-20-2011 09:44 PM
Trouble with Transmission Trouble Codes Toaster_Man S-Series Tech 0 05-22-2008 06:32 PM
92 saturn trouble codes jaylie S-Series Tech 12 09-16-2005 11:44 AM
