Old 08-30-2012, 08:47 PM   #1
krateliff
krateliff is on a distinguished road
Default service engine light error code p1780 and u2105
I have a 2002 Saturn L300 that failed inspection due to the service engine light being on. Auto Zone said the error codes are p1780 and u2105. The car runs fine. The service engine light only comes on after the car has run for 5 - 10 minutes. Does anyone have any ideas on what could be causing this?
Thanks in advance for any help!
Add to krateliff's Reputation
Rate the quality of this post and help krateliff reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
krateliff is offline   Reply With Quote
Old 09-01-2012, 08:19 PM   #2
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Default Re: service engine light error code p1780 and u2105
Both of these trouble codes relate to communications through the CAN bus system between your cars various control modules. In this case it is between the Powertrain Control Module and something else. A likely cause is a poor connection at one of the multi-pin connectors at the firewall or at the UHFB. I would also pull the modules from the top of the glove compartment and the inside of the firewall and check those connections. You are looking for corrosion or maybe a dark, burned look. Of course there are many other possible causes. A broken otherwise damaged wire is one that comes to mind.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
U2105 and P1780 codes geno607 L-Series Tech 12 10-11-2012 03:40 AM
My First Engine Trouble Code...P0727 and P1780 Jonnyferrari L-Series Tech 1 05-24-2012 09:33 PM
Codes U2105, P1780 & P0304 2000 LW2 rigo009 L-Series Tech 3 02-26-2012 03:50 AM
SES light and code P1780 2000 LW 3.0V6 Alviarin L-Series Tech 1 02-14-2006 11:34 PM
Service Engine Soon Light – Error Code P0133 Filo S-Series Tech 5 02-16-2005 03:49 PM
