Old 08-29-2012, 06:42 PM   #1
GeoPappas
GeoPappas is on a distinguished road
2007 AURA XE
Default P0449 (Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction)
2007 Aura XE
2.5L V6
We have a check engine light showing on the dash (it looks like a little engine). We used a scanner to read a P0449 (Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction) from car's computer.
Anyone have any experience on this?
2007 Saturn Aura XE V6
Add to GeoPappas's Reputation
Rate the quality of this post and help GeoPappas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GeoPappas is offline   Reply With Quote
Old 08-29-2012, 08:01 PM   #2
greenman
2009 AURA XE
Default Re: P0449 (Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunctio
It could be a bad evap canister vent solenoid valve or it's circuit. Can't know which without troubleshooting. It's not an easy valve to replace as it's above the fuel tank.
Add to greenman's Reputation
Old 08-31-2012, 10:06 AM   #3
GeoPappas
2007 AURA XE
I got a chance to take a look under the car.
As you can see from the image below, the part has two large openings (one on each side). Are hoses supposed to be attached to both sides?
I ask because there is nothing attached to the upper opening.
Also, the instructions from AllDataDIY says to loosen three of the four fuel tank strap bolts. How long are these bolts? And are they all the same size? I want to loosen them so that there is some working room, but I don't want to loosen them too much and have them fall out (and possibly cause damage if the fuel tank falls and shifts).
Old 08-31-2012, 01:59 PM   #4
greenman
2009 AURA XE
You found the problem. Did you see the detached hose?
Old 08-31-2012, 06:44 PM   #5
GeoPappas
2007 AURA XE
No. I looked around, but didn't see any other hose. What is the hose supposed to attach to?
Are you sure that there is supposed to be a hose on both sides?
I ask because all of the AllDataDIY.com images show only one side attached. For example, here is one of the images:
In addition, their instructions only talk about detaching one hose from one side.
Old 08-31-2012, 08:45 PM   #6
greenman
2009 AURA XE
My bad. That's just the fresh air inlet. Sometimes they'll have a hose attached on that side.
Old 08-31-2012, 08:59 PM   #7
greenman
2009 AURA XE
Can't say how long they are but support the tank with jacks or jackstands if that's all you have. If there is much fuel in it it'll be heavy.
Old 09-19-2012, 07:48 PM   #8
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Is this problem related to the P0455 code?
I have had the same code come up despite replacing the gas cap.
Any help would be appreciated...
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 09-20-2012, 03:48 PM   #9
greenman
2009 AURA XE
455 means the vacuum leak test is repeatedly failing. There is a breach somewhere in the system. You can start by getting the system smoke tested. Sometimes you can just clear the code & it won't come back, at least for awhile. Sometimes a new gas cap solves it.
Diagnostic Aids
Inspect for a loose, missing, incorrect, or damaged fuel fill cap.
Verify that the fuel filler neck sealing surface is not distorted or damaged.
To help locate intermittent leaks, use the J 41413-200 (J 41413-100) EEST to introduce smoke into the EVAP system. Move all EVAP components while observing smoke with a high intensity white light.
Reviewing the Failure Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
A condition may exist where a leak in the EVAP system only exists under a vacuum condition. By using the scan tool Purge/Seal function to create a vacuum, seal the system and observe the FTP parameter for the vacuum decay, this type of leak may be detected.
If a small leak is difficult to find, it may be necessary to remove the EVAP components and leak test them one at a time using the adapters in the J 41413-300 Kit .
Check engine light says Vac Leak Detection (nvld) canister vent solenoid circuit low Litey Astra General 7 02-28-2013 05:47 PM
Canister vent solenoid/Vent control solenoid. hulkbam Vue Tech 4 01-10-2012 02:53 PM
SES light - Evaporative Emmisions Malfunction sparky741 2008 Vue 6 11-25-2008 10:17 PM
Idle Control System Malfunction cdw S-Series Tech 2 02-17-2007 03:08 PM
Idle Control System Malfunction alisa2089 S-Series Tech 5 08-15-2006 09:32 PM
