#1 | ||||
![]() Join Date: Aug 2012
![]() We need to replace the radiator fan on my 2003 Saturn Vue because one of the blades busted. My husband has the fan disconnected but he doesn't have the room to get it out. Any suggestions? Or how do you get it out?
Thanks in advance!!!! Kelli
#2 | ||||
![]() Never had to do one but if I recall correctly from training the cross member over the rad needs to be removed.
... A lousy day in paradise is still a day in paradise.
#3 | ||||
![]() Join Date: Dec 2007
2002 VUE 2.2L
![]() It's a little tougher than it looks. The front bumper cover has to come off, the radiator drained and all the surrounding plastic removed/loosened. Then the radiator hoses and upper mount brackets have to come off and the radiator/condenser assembly is lifted and leaned forward so the fan/shroud can slide out. That's why you really want to be sure the fan is bad!
#4 | ||||
![]() Thank you gentlemen on your responses!!!! Unfortunately the fan is bad. Hubby can see the busted fan blade.......
I'm sure I will hear a lot of swearing outside tomorrow. LOL Thank you again! Kelli
#5 | ||||
2002 VUE 2.2L
![]() Didn't mean to question your troubleshooting skills, I bet a broken fan blade is a major attention getter
#6 | ||||
![]() ![]() ![]() Join Date: Feb 2006
2006 VUE Red Line
2004 ION-3 Quad Coupe
![]() I replaced my cooling fan assembly on my '06 Redline and its really not a bad job. Replacing the radiator fan assembly really isn't too bad/complicated of a job, its just time consuming. As mentioned above, you basically you have to remove the bumper cover and headlights, which are mainly held in by clips and a couple bolts, then disconnect the coolant lines from the radiator, move radiator out of the way and slide the cooling fans off of the radiator. Then repeat in the reverse order to put it back together. Time consuming, but not terrible.
As long as you take your time with the job, it really isn't bad at all. Best of luck with your replacement!
Radiator Fan Assembly removal | mit2k14u | Ion Tech | 6 | 02-17-2017 09:14 AM |
2003 Saturn L200 Radiator Fan Control Module | Bobicon | L-Series Tech | 7 | 04-29-2013 02:12 PM |
Radiator drain cock removal | kerry7 | Vue Tech | 3 | 04-30-2012 11:59 PM |
need help w/removal of radiator stroud, tie bar | Fnicolai | L-Series Tech | 2 | 01-07-2009 11:01 PM |
Radiator removal, how long ? | Scyan | L-Series Tech | 5 | 04-29-2003 09:32 PM |
