Old 07-24-2012, 08:27 AM   #1
mjspurs23
mjspurs23 is on a distinguished road
Default Recommended Spark Plugs & Wire Set Brand?
I plan on replacing the spark plugs & wire set in my 2000 SL1 SOHC 137K miles. When I looked up the plugs for my car there were just so many to choose from NGK, Autolite, Champion, Ac Delco, etc. For the wireset, there are wires from Ac Delco, Bosch, Duralast, and others.
Recommendations on which brand of plugs & wire set to get?
Add to mjspurs23's Reputation
Rate the quality of this post and help mjspurs23 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjspurs23 is offline   Reply With Quote
Old 07-24-2012, 08:45 AM   #2
Default Re: Recommended Spark Plugs & Wire Set Brand?
I go with NGK plain copper's, or V-Power if you can find them for spark plugs and Napa Premium wires.
Old 07-24-2012, 09:24 AM   #3
mjspurs23
Where can I find Napa premium wires?
Old 07-24-2012, 09:53 AM   #4
Should be in stock, find a store here: http://napaonline.com/FindLocation/find-a-location.aspx
or online at www.napaonline.com.
Old 07-25-2012, 08:50 AM   #5
mjspurs23
I had already purchased Autolite plugs & wires from Autozone a few weeks ago. Will these run well?
Old 07-25-2012, 10:57 AM   #6
pawel
pawel is on a distinguished road
I had Napa premium wires and kept getting CEL p0340. Replaced them with Denso wires and the code had not showed up since than. You can tell the Denso wires are better quality and were cheaper from amazon.
Add to pawel's Reputation
Rate the quality of this post and help pawel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pawel is offline   Reply With Quote
Old 07-25-2012, 11:02 AM   #7
The quality of any given brand of mid priced direct fit wires is hit or miss depending on the phase of the moon. The Magnecor 7mm or 8mm wire set will function correctly and will last longer than the set of plugs. They will cost you about $20.00 more than the mystery quality set. http://www.magnecor.com/magnecor1/main.htm and these are the ones you want. http://www.magnecor.com/magnecor1/main.htm
Old 07-25-2012, 02:07 PM   #8
martensitic
martensitic is on a distinguished road
1996 SL1
I had random stumbling/misfire under load with brand new Autozone/Duralast wires that disappeared when I replaced them with OEM wires from saturnparts.net. YMMV
1996 Saturn SL1 SOHC, A/T, 116k, NYC
Add to martensitic's Reputation
Rate the quality of this post and help martensitic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
martensitic is offline   Reply With Quote
Old 07-25-2012, 04:03 PM   #9
AndreasChen
AndreasChen is on a distinguished road
Try ACDelco wires from Amazon
02 Saturn SC2, noisy, trying to quiet it down...
Add to AndreasChen's Reputation
Rate the quality of this post and help AndreasChen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AndreasChen is offline   Reply With Quote
Recommended spark plugs for Honda 3.5L V6 L66 Engine Dante Vue Tech 5 08-12-2015 08:25 PM
What are the recommended spark plugs for 3.5? Anjey Aura General 3 04-09-2011 12:07 PM
recommended brand for spark plug wires? alejohome S-Series Tech 21 07-01-2009 03:24 AM
Opinions Wanted: best spark plugs and wire sets 93sc2OHguy S-Series Tech 8 12-17-2007 12:53 PM
ignition wire/spark plug wire - resistance/ohms Heartbeat - '95 SL2 S-Series Tech 3 10-17-2005 01:09 PM
