Old 07-23-2012, 08:54 PM   #1
Niz
Niz is on a distinguished road
1998 SL1
Default 1998 Saturn SL1 IAT Sensor
I recently checked my code at O'Reilly's and it came back with a P0113. Something to do with the IAT sensor. I went to check it out under the hood, and i found this thing sticking out of a tube under the air filter. I don't know for sure if it is the IAT sensor but i'm assuming it is. The this is, this sensor isn't connected to anything. I'm not sure if it's supposed to be like this but i'm assuming a sensor should be connected to some wires and the computer right? I have attached some pictures. Should i replace the IAT sensor? And where are the wires for this sensor?
Add to Niz's Reputation
Rate the quality of this post and help Niz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Niz is offline   Reply With Quote
Old 07-23-2012, 09:17 PM   #2
off-track
off-track's Avatar
Default Re: 1998 Saturn SL1 IAT Sensor
Welcome to the group!
Yes that's the IAT and it looks like the connector is on it. The wires are in that smaller split flex right under it in the second picture. They should be brown and black.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 07-24-2012, 12:25 PM   #3
Niz
1998 SL1
DO you think i should replace the sensor since it came up with the P0113 code?
Old 07-24-2012, 01:00 PM   #4
Melissa_M
Melissa_M is on a distinguished road
I don't see the wires.
1999 SL2 MANUAL ~76K
Add to Melissa_M's Reputation
Rate the quality of this post and help Melissa_M reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Melissa_M is offline   Reply With Quote
Old 07-24-2012, 01:22 PM   #5
Niz
1998 SL1
Yeah, i went to check it out again. I couldn't find any wires connecting to it. I took a close up shot of it.
Old 07-24-2012, 01:24 PM   #6
That explains the IATS code. Need a new connector/pigtail. Actual new one is a bit over $30 last I knew, new-to-you is whatever you pay for in a junkyard or pay someone on here to send you one.
Old 07-24-2012, 01:32 PM   #7
Niz
1998 SL1
Where am I supposed to connect the wire from the new sensor?
Old 07-24-2012, 01:52 PM   #8
Niz
1998 SL1
I checked with O'Reilly's and they said they had a sensor for $12.99 but it was just the sensor itself. I asked him if they sold the wiring too and he told me to contact the dealer.
Old 07-24-2012, 02:05 PM   #9
AIRTEX / WELLS Part # 1P1439 $27.79 plus s/h
rockauto.com
Old 07-24-2012, 03:06 PM   #10
You don't need a new IAT sensor - they hardly ever go bad. Look at the thin plastic corrugated tube - it's a "protector" for a bunch of wires. I circled it in your picturel Look for a couple of loose wires in this loom - when you get your new connector, you will solder and shrinkwrap the two wires to the loose wires in the loom. You will probably want to remove the air filter box for this.
This video is for an identical sensor, the ECTS - but you will be pulling the old connector off the sensor, soldering the new connector, then plugging it onto your IATP
Old 07-24-2012, 04:34 PM   #11
Niz
1998 SL1
I went to look for the wires you were talking about and i found the wires. They still have the connector things on it and i also found a white adapter type thing. The were barely together and when i picked the wire up, the white thing fell off. I tried putting it back together but i don't know how it's supposed to go back together. I took some pictures again.
Old 07-24-2012, 07:42 PM   #12
off-track
off-track's Avatar
Yeah, to sum it up, it's broken. I suspected from your first post but it was raining and too dark out for me to take a picture. Part of the connector is still attached to the harness and the other (black part) is on the sensor itself. You squeeze the flanges on the black section to release the lock and remove it.
As aloc said.. you can get a new connector like fetchit posted, grab one from the nearest junkyard for ~$5 or, PM lowsaturn as he had a box full of them that he was selling for ~$15 plus shipping.
The attached is how it should look.
Added OEM CC
Old 07-24-2012, 08:52 PM   #13
Niz
1998 SL1
I actually took the black plastic tip off the sensor and put in the wires through it, clipped the white thing on it and clipped the black thing back on the sensor. I have no idea if it worked or not but it looks like the picture you attached. I'll have to get the code checked again.
Old 07-24-2012, 09:09 PM   #14
off-track
off-track's Avatar
It's possible that will work as it looks like the connector clips are still intact in the white piece? I'd bet that it will probably fall off again though? If re-connecting it clears the code (it may take a few ignition cycles) I would suggest a dab of super glue on that center tab to hold it all together. Clean both sides thoroughly first though!
I don't recall ever seeing this pop up before??
Added OEM CC
Old 07-24-2012, 09:20 PM   #15
Niz
1998 SL1
Yeah we'll have to see. The check engine light is still on. I'll check tomorrow to see if anything happens.
Old 07-24-2012, 09:30 PM   #16
off-track
off-track's Avatar
Just checked.. other than resetting the MIL via PCM-B removal or a clear command from a scan tool, it will take "four successive ignition cycles in which the diagnostic will run flawlessly" to clear the DTC.
BTW Niz, add your car's specific (yr/model) to your profile and at least an approximate location. It helps to easily provide relevant information for certain problems/issues that will be included automatically in every post.
Added OEM CC
Old 07-25-2012, 10:42 AM   #17
^ ^ ^ +1, PCM-B fuse is probably quickest/easiest. It's in the UHJB, or under hood junction box, which is right by the airbox. There is a large, knob/screw thingie for removing the cover, and on the inside of the cover is a diagram for the fuses and relays. The PCM-B is at one of the corners (you should have a white plastic fuse puller inside there - makes it very easy)
When I saw the cap had fallen off, this was the first fix I thought of:
Old 07-25-2012, 04:50 PM   #18
Niz
1998 SL1
So should I pull the fuse and put it back in? Sorry, I don't really know this stuff.
Old 07-25-2012, 04:57 PM   #19
Pull the fuse out, leave it out 5-10 seconds, put back in. Unlucky people may find they need to keep it out a "massive" 30 seconds for it to properly clear the codes.
You could unplug the battery as well, but that will also remove all customized radio settings, usually including the clock.
Old 07-25-2012, 07:50 PM   #20
Niz
1998 SL1
I actually just reset the code with the code reader. The CIL came back on on the drive home. I'm thinking about going to the junk yard to pull one out from another Saturn and solder the wires like you guys said. If that doesn't work, I might just have to buy those wires from rockauto.
Bank 1 Sensor 1 O2 sensor in a 2003 V6 Saturn Vue fwimbe01 Vue General 1 12-07-2011 08:24 PM
1998 SW2 1.9L efi/ohc TEMP SENSOR? EGR? beachbummm069 S-Series General 2 03-07-2010 02:23 PM
1998 SC2 sensor locations Slimbob S-Series Tech 7 06-18-2007 01:59 PM
Re: 1998 SL P0500 Vehicle Speed Sensor Malfunction sheehan_rs S-Series General 2 03-16-2006 01:12 AM
1998 SL P0500 Vehicle Speed Sensor Malfunction sheehan_rs S-Series Tech 7 02-21-2006 12:53 AM
