Old 07-23-2012, 12:03 PM   #1
mjspurs23
mjspurs23 is on a distinguished road
Default Muffler Strap
2000 Saturn SL1 SOHC, 130K miles, original muffler (to my knowledge). My muffler strap fell off recently, and I need to install a new one. Anyone have a how-to on replacing it? Much thanks!
Add to mjspurs23's Reputation
Rate the quality of this post and help mjspurs23 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjspurs23 is offline   Reply With Quote
Old 07-23-2012, 01:09 PM   #2
trottida
trottida is a glorious beacon of lighttrottida is a glorious beacon of lighttrottida is a glorious beacon of lighttrottida is a glorious beacon of lighttrottida is a glorious beacon of lighttrottida is a glorious beacon of light
trottida's Avatar
Default Re: Muffler Strap
Not much to it as far as I understand it. There is a slot in the body forward of the tank that the "T" end of the strap fits into which creates a hinge and a bolt at the other end of the strap that bolts into a threaded hole. There is also a plate the bridges between both straps which is held on with tabs that feed through the straps. Twist the tabs to straighten them and push them through to remove the plate from the strap.
Current rides
2001 SL1 MT (410,500 km @ 11/2017)
1999 SL2 MT (251,500 km @ 11/2017)
2011 Suburban LT (101,450 km @ 11/2017)
:canada:
Add to trottida's Reputation
Old 07-23-2012, 01:37 PM   #3
mjspurs23
Ok. It appears that the muffler strap for the original muffler is rather hard to come by, and I've heard of makeshift muffler straps that work for the time being (plumber's strap being one of them). Would that work?
Old 07-23-2012, 01:48 PM   #4
trottida
trottida's Avatar
My apologies, for some reason I read "gas tank strap" rather then "muffler strap". Please disregard my previous response.
Plumber strap would work in a pinch but something that is stainless steel will last longer if you're in an area exposed to road salt.
Current rides
:canada:
Old 07-23-2012, 03:11 PM   #5
mjspurs23
Not to worry.
Other than the strap, what tools/parts are needed to complete the job?
Old 07-23-2012, 08:47 PM   #6
papoopeepoo
papoopeepoo is on a distinguished road
papoopeepoo's Avatar
2001 SC1
I just did a muffler strap replacement today, it was easy and straightforward. I didn't need to jack the car up, I just applied the parking brake. I used an OE part from GM dealership. The strap sold on rockauto and other parts stores are for aftermarket mufflers and will NOT fit the OE muffler. I bought a 13mm nut to accompany the strap since the it didn't come with one, and the guy at the NAPA store gave me a bolt, lock washer, and nut of some SAE size like 7/16 to hold the hanger to the strap. Any bolt will do as long as its thing enough to fit the opening and long enough to thread easily in a tight area.
The old strap was so corroded it just snapped when I tried to remove the nut. I never actually got the nut loose, even with PB Blaster, so I'm glad I got the new one.
Also, the hanger is a separate part, it's only $5 at the dealer, so make sure to pick one up if you need it.
Tools needed include :
-13mm deep wall socket -- to remove the tightening nut (only the nut moves, not the bolt head) if you are lucky enough to have a nut that hasn't ceased on you.
-Hands (wear gloves)
Also, you might find it easier to remove the left rear wheel while doing the job to free up space.
Add to papoopeepoo's Reputation
Rate the quality of this post and help papoopeepoo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
papoopeepoo is offline   Reply With Quote
Muffler Strap billdo S-Series Tech 10 02-20-2011 11:23 AM
Muffler strap for 01' SC2? Usumgal S-Series Tech 10 10-29-2008 10:26 PM
SL2 muffler strap Project84 S-Series General 3 03-15-2007 11:09 PM
muffler strap dcp S-Series Tech 9 06-20-2005 03:43 PM
New muffler strap Wired220 S-Series General 4 04-08-2004 10:12 PM
