Old 07-19-2012, 11:12 AM   #1
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2003 VUE 2.2L
Default Coolant leak - 2001 SL1
I sold this car to a nice young couple and they brought it back to me after a few months, saying the car was leaking coolant.
She had her uncle who's a mechanic put the car on his lift, but he couldn't find any leaks, even with the car running. They say they can fill the reservoir up and drive around the city for 3-4 days before the coolant light comes on, but if they're on the highway, it's every hour!
I replaced the radiator and water pump before I sold the car, and those look fine. However, the back of the engine is covered in dried coolant and a few drips.
It looked like it might be coming from the intake? Does that gasket have coolant running through it?
I tried to snap a couple pics from under the car:
Help!
shawn
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 07-19-2012, 11:26 AM   #2
dsquare86
dsquare86 is on a distinguished road
2002 SL1
2001 SL2
Default Re: Coolant leak - 2001 SL1
I am not sure about the SOHC, but IIRC the DOHC plastic intake manifold has a coolant passage from the head run into it on that side on the 3rd gens.
Derek
2002 Saturn SL1 SOHC 5 Speed.
2001 Saturn SL2 DOHC 5 Speed - Retired.
Add to dsquare86's Reputation
Rate the quality of this post and help dsquare86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dsquare86 is offline   Reply With Quote
Old 07-19-2012, 12:29 PM   #3
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
When I changed my intake manifold gasket, I recall a little, rectangular, rubber seal on a port in the head. Believe this was a coolant port, but I have no idea where the coolant went, if anywhere. The FelPro replacement gasket did not come with this little seal, so I reused the old one. Someone on here surely knows what this port is for.
BV22
2002 SC1 5M
305k 02/18
Add to BV22's Reputation
Old 07-19-2012, 12:36 PM   #4
dsquare86
2002 SL1
2001 SL2
On the DOHC, it connects to the little 5/16's or whatever size coolant hose that runs over to the coolant reservoir.
Derek
Old 07-19-2012, 01:52 PM   #5
ShawnV
ShawnV's Avatar
2003 VUE 2.2L
I checked out some old threads and it seems that the Gen 3 SOHC intake manifold gasket is known for high idle and leaking coolant!
I talked to them again with a price for the repair, but they weren't interested. They're leaving on a 500 mile trip tomorrow and said they will just keep refilling it with water. I get the feeling that these people can't afford much, but they might be in for a blown engine sooner than later.
shawn
Old 07-19-2012, 02:01 PM   #6
BV22
2002 SC1
I can certainly vouch for the vacuum leak - that's why I changed my gasket. I can also imagine that if that little seal had fallen on the ground when I separated the manifold, I would have never known it had been there and put the car back together without it. Maybe that is what happened to this car?
BV22
2002 SC1 5M
305k 02/18
Old 07-19-2012, 02:15 PM   #7
ShawnV
ShawnV's Avatar
2003 VUE 2.2L
It could be, but it's not my problem any more! You can only be so helpful in offering advice. The uncle mechanic is going to replace the gasket when they get back from their trip, so I'm out of it now.
Old 01-27-2014, 05:26 PM   #8
konakani
konakani is on a distinguished road
HELP! I am new to the Saturn family but I have a problem that I need some advice. I just bought a 2001 Saturn SL1 on Saturday. I drove it to work this morning and the coolant light came on, the coolant level was low when i checked it BUT most importantly there was a spot where the coolant obviously leaked on ground at front of the car, driver's side. I also noticed that when I place the car in 'park' the idle INCREASED instead of backing off! Please Help! I bought the car because I blew a water pump on my Mazda B3000 and bent a push rod! I must have reliable transportation because there is NO organized bus system.
Add to konakani's Reputation
Rate the quality of this post and help konakani reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
konakani is offline   Reply With Quote
Old 01-27-2014, 05:52 PM   #9
bluesl2
bluesl2's Avatar
You should start a new thread but I'll respond to you here. I would closely inspect your radiator by the upper hose connection, they like to crack there, it's possible the intake gasket may be leaking coolant but it's rare on a sohc engine. For the high idle, the next time it does that shut the car off and wait about 30 seconds or so. Then restart and see if the idle goes back to normal. If it does, the tps is probably bad and needs replacement.
Add to bluesl2's Reputation
Old 01-27-2014, 06:23 PM   #10
konakani
Thank you for responding.....sorry about not starting a new thread....I'm a 'newbie' to this forum discussion stuff. Okay....to extend my ignorance....How do I start a new thread?
Old 01-27-2014, 09:50 PM   #11
bluesl2
bluesl2's Avatar
Click the "new thread" and go from there, I see you already figured it out though with your new thread.
2001 DOHC Coolant Leak richamer1 S-Series General 2 01-27-2014 05:37 PM
2001 SW2 Intake Manifold Coolant Leak - A cautionary tale BrownSaturn S-Series Tech 1 09-09-2011 12:50 PM
2001 SL2 twin cam coolant leak iuam S-Series Tech 2 07-26-2010 10:24 AM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 11:56 AM
3.0L V6 coolant leak... sdlynx L-Series Tech 7 06-08-2001 10:00 AM
