Old 07-16-2012, 11:14 AM   #1
bbax13
bbax13 is on a distinguished road
Default 99 SL1 has power but won't start
I drove about a half mile to the gas station got out and when i returned to leave my dash lit up all the lights but would not even try to turn over. I replaced the battery a month ago so i don't think it's anything there. My question is this the starter, ignition switch, solenoid, a sensor in the gear box or something else?? I'm going based on some things I have read on the web but can't really get a solid idea of what it may be. I will say that i may have turned the car off while it was in reverse but i'm not entirely sure. I got the car back to my house and tried turning it on once a day for the next couple days, on the fifth day it has started back up but i'm afraid to take it anywhere for fear it may happen again. Any help is appreciated.
Add to bbax13's Reputation
Rate the quality of this post and help bbax13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bbax13 is offline   Reply With Quote
Old 07-16-2012, 11:40 AM   #2
Default Re: 99 SL1 has power but won't start
Most likely the starter is worn out if its the original one. A last ditch effort if battery, cables, and connections are on good working order would be to bang the starter body a few times with a piece of 2x4 lumber or steel rebar - a successful start means the starter needs to be replaced. Even if the starter didn't come to life after a little beating, replace it.
Old 07-16-2012, 12:25 PM   #3
theshackle
theshackle is on a distinguished road
Does the car still have power after you turn the key? If it does then it might be the starter. I had a similar issue with a Crown Victoria used to have and it did turn out to be the starter. Before you replace anything, check all the little things first like the fuses and wiring, make sure the leads and grounds going to and from the starter motor are damaged or corroded. If that all looks good the next step might be the starter. You can usually find one cheap at a salvage yard but there is no guarantee that it will be in any better shape than the one you're taking off, so you might be better off buying a new or rebuilt starter motor.
Add to theshackle's Reputation
Rate the quality of this post and help theshackle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
theshackle is offline   Reply With Quote
Old 07-16-2012, 01:07 PM   #4
bbax13
Yep it still has power after turning the key. My first instinct was the starter just wanted some more advice from others before i startd in on taking things apart. I'll be sure to check the wiring and stuff as well. It was just odd to me that it started back up several days later.
97 SL2 has battery power, but won't start davemack S-Series Tech 4 10-25-2010 03:59 AM
Won't start and no power daniels20 L-Series General 1 10-21-2009 06:03 PM
power cut off when attempting to start... bskicrash1 S-Series General 3 08-16-2006 07:00 PM
99 SL2, won't start or turn over, has power jimsz S-Series General 12 11-03-2005 05:24 PM
SL2 Loss of power & won't start mctacco S-Series Tech 3 07-19-2005 11:58 PM
