Old 07-11-2012, 11:02 AM   #1
jerryt14
jerryt14 is on a distinguished road
Default 2004 Saturn Vue radio stopped working
I have a 2004 Saturn Vue. The entire radio stopped working including the clock.
I checked the owners manual and see the fuse for the radio in the front passenger fuse box. I took out the fuse but it doesn't look blown.
I'm not sure if the fuse box under the hood has a fuse for the radio. Does it?
So, what can I do to get my radio working again? Which fuse should I look at? Or could there be another issue?
And, does anybody have a fuse diagram for the 2004 Saturn Vue that is more descriptive than the manual?
jerryt14 is offline   Reply With Quote
Old 07-11-2012, 11:12 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2004 Saturn Vue radio stopped working
Sounds like something in B+ circuit.
There are two fuses in the IP fuse block. There'll be a third in the underhood box if you have amplifier (doubt if this would affect clock).
See attached thumbnail.
Old 07-11-2012, 07:17 PM   #3
ruley73
ruley73's Avatar
2007
I would check the BATTERY 40A fuse in the underhood fuse block.
If your Vue came with a factory-installed subwoofer, you will also have a fuse labeled PREM AUD 20A at the underhood fuse block.
There are two fuses in the instrument panel fuse block. One is RADIO 10A and the other is RADIO (IGN) 10A.
If all fuses check out fine, the radio is probably defunct. You can take it out and double-check the plug going to it just to be sure though.
Replacements can be found on ebay for under $50 unless you have an MP3-capable six-disc radio which goes for around $100.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone*
2007 Chevy Equinox LT 196K miles
2018 Chrysler Pacifica Touring L 53K miles
Tags
radio
Battery died/radio stopped working Badman Aura General 4 01-12-2010 01:54 AM
Won't turn over & key fob stopped working while wiring radio yottabit S-Series Tech 3 06-20-2009 08:56 PM
XM radio stopped working... REDLINE_IT Vue General 3 06-28-2008 02:14 PM
'04 Vue Radio stopped working (but CD/MP3 still works) russellhome Vue General 4 01-18-2008 08:03 PM
radio stopped working oldgoat S-Series General 3 08-11-2005 05:24 PM
